VIN change from Dump EDC17C46 - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Automotive Airbag, Dash, ECU, IMMO. (https://mhhauto.com/Forum-Automotive-Airbag-Dash-ECU-IMMO) +--- Thread: VIN change from Dump EDC17C46 (/Thread-VIN-change-from-Dump-EDC17C46) |
VIN change from Dump EDC17C46 - michi01 - 06-14-2026 hy, can anyone change VIN in this Dump? New VIN in .txt Thanks
RE: VIN change from Dump EDC17C46 - Berrymore - 06-14-2026 (06-14-2026, 02:00 PM)michi01 Wrote: hy,hi I changed the VIN number in the EEPROM. There is no VIN number stored in the flash. RE: VIN change from Dump EDC17C46 - forti - 06-14-2026 (06-14-2026, 02:22 PM)Berrymore Wrote:(06-14-2026, 02:00 PM)michi01 Wrote: hy,hi I changed the VIN number in the EEPROM. There is no VIN number stored in the flash. youre solution is bad EEP block CRC BAD. if you want proper priv RE: VIN change from Dump EDC17C46 - Berrymore - 06-14-2026 (06-14-2026, 02:33 PM)forti Wrote:Why would I need to calculate the checksum? The programmer recalculates it automatically during writing. And the VIN was changed correctly; he didn't ask me to calculate the checksum.(06-14-2026, 02:22 PM)Berrymore Wrote:(06-14-2026, 02:00 PM)michi01 Wrote: hy,hi I changed the VIN number in the EEPROM. There is no VIN number stored in the flash. RE: VIN change from Dump EDC17C46 - forti - 06-14-2026 (06-14-2026, 03:42 PM)Berrymore Wrote:i didn t say is not change correctly.(06-14-2026, 02:33 PM)forti Wrote:Why would I need to calculate the checksum? The programmer recalculates it automatically during writing. And the VIN was changed correctly; he didn't ask me to calculate the checksum.(06-14-2026, 02:22 PM)Berrymore Wrote: hi I changed the VIN number in the EEPROM. There is no VIN number stored in the flash. eprom is not recalculate by any programer, if is not done youre change will not work and ecu cant work normal. |
