Need Help Renault Zoe Low Voltage Converter replacment. - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Automotive Airbag, Dash, ECU, IMMO. (https://mhhauto.com/Forum-Automotive-Airbag-Dash-ECU-IMMO) +--- Thread: Need Help Renault Zoe Low Voltage Converter replacment. (/Thread-Need-Help-Renault-Zoe-Low-Voltage-Converter-replacment) |
Need Help Renault Zoe Low Voltage Converter replacment. - cundi77 - 06-14-2026 I have to replace Low Voltage converter on a Renault Zoe 2015.I find a replacment part on second hand but not the same part number they look exactly the same. orig 292A01143R Replacement 292A00678R. I want to know if they are compatible. Thx RE: Need Help Renault Zoe Low Voltage Converter replacment. - cundi77 - 06-16-2026 (06-14-2026, 09:04 PM)cundi77 Wrote: I have to replace Low Voltage converter on a Renault Zoe 2015.I find a replacment part on second hand but not the same part number they look exactly the same. Case closed .the parts were perfectly compatible .car working fine everything ok. |
