dts 9.02 and projects problem - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: dts 9.02 and projects problem (/Thread-dts-9-02-and-projects-problem) |
dts 9.02 and projects problem - filip050 - 06-15-2026 Hi, DTS Monaco 9.02 is installed and licensed. I copied BR_212_MOPF project from the DTS Monaco Projects Database (48GB package) to: Code: C:\ProgramData\Softing\DTS9\DTSProjectsHowever, Monaco only shows Example_Project, OBD and SAE_J1939. Renaming the folder did not help. Is there an additional import/registration procedure required for these Mercedes projects? How do I make DTS Monaco detect BR_212_MOPF projects? RE: dts 9.02 and projects problem - Sam!k - 06-16-2026 After copying folder, need to restart DTS. And check current folder in config. RE: dts 9.02 and projects problem - job - 06-16-2026 if still not working, manual import . |
