RVK MM7GV READER - FREE FOR MHHAuto Members only - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: VAG Group VW , Audi, Seat, Skoda, Bentley Discussions. (https://mhhauto.com/Forum-VAG-Group-VW-Audi-Seat-Skoda-Bentley-Discussions) +---- Thread: RVK MM7GV READER - FREE FOR MHHAuto Members only (/Thread-RVK-MM7GV-READER-FREE-FOR-MHHAuto-Members-only) |
RVK MM7GV READER - FREE FOR MHHAuto Members only - BenzzGuyy - 09-14-2026 🔥 RVK MM7GV READER — FREE FOR MHH AUTO MEMBERS 🔥
A useful Windows tool for workshops and locksmiths working with VAG Magneti Marelli IAW 7GV ECU EEPROM dumps and supported NEC instrument clusters. 💻 Works directly with dump files — no OBD connection or cable required. 🛠️ Supported Data 🔹 MM7GV ECU — Magneti Marelli IAW 7GV, external 95320 EEPROM (4096 bytes) 🔹 VAG / VW Polo NEC clusters — supported 24C32 / 24C64 data 🔹 160 / 198 / 256-byte decoded immobilizer blocks 🔹 VIN, PIN, CS, MAC, Key 1 / Key 2 and Power Class reading ⚙️ Main Features ✅ Automatic MM7GV mask and ECU variant detection ✅ VIN, PIN, CS and MAC editing ✅ Automatic CRC1 / CRC2 recalculation ✅ IMMO OFF / ON and Virgin functions ✅ Cluster → ECU synchronization ✅ Supported cluster mileage read / write ✅ Batch dump analysis and TXT reports ✅ Original dump remains unchanged — modified data is saved separately 🚗 Typical Applications Volkswagen Polo 6R / 6C, Polo Sedan / Vento, Škoda Fabia II, Roomster, Rapid, Seat Ibiza 6J and other VAG vehicles using compatible EA111 MPI engines. 🆕 Version 2.0.0 • MM7GV EEPROM recovery from a database of original dumps • Improved dump validation • Support for VW Polo white NEC35xx clusters • Better ECU variant detection • Improved cluster-to-ECU synchronization 🎁 FREE FOR MHH AUTO MEMBERS
This is being shared with the community for educational and workshop use.
🔑 LICENSE ACTIVATION Want to activate the full version? 1️⃣ Copy your HD ID / Machine ID from the program 2️⃣ Hit THANKS 👍 on this post 3️⃣ Reputation Rate ⭐ 4️⃣ Send me a PM 📩 with your HD ID I will send you the activation key after processing your request. ⚠️ Please send your HD ID by PM — do not post it publicly. 💬 Enjoy the tool and share your feedback with the community. 💬 If you find the tool useful, share your feedback and help other members. RE: RVK MM7GV READER - FREE FOR MHHAuto Members only - Slav1984 - 09-14-2026 hi can i have activation please my id : 647f4084698319e310fa3c99e60f161afc31d69ce4fadecd1a5b8c3b0bf39649 thanks in advance |
