benz GLK 350 4MATIC suction problem - Printable Version
+---- Thread: benz GLK 350 4MATIC suction problem (/Thread-benz-GLK-350-4MATIC-suction-problem)
benz GLK 350 4MATIC suction problem - gimba - 04-23-2015
hello can someone help out on what to do. its a benz GLK 4MATIC 2009. Once the fuel is below quarter tank vehicle misfire seriously. fuel is not transferring from the second tank to the order one to pump fuel. pls any advice on what is causing the lack of suction and what to do.
thanks in advance.
RE: benz GLK 350 4MATIC suction problem - dominion1234 - 10-28-2016
I have come across this problem several times, if the fuel pump as no good pressure, it courses it and also if the filter side of tank as problem, it also courses it. First you have to measure the fuel pulp pressure if it is ok, if it is ok, them change the complete filter kit for a known good one.
RE: benz GLK 350 4MATIC suction problem - kin1830 - 10-28-2016
also check the inner return hoes from filter-fuel regulator to the fuel pump
