Ford Transit ABS fault U0401 invalid data from ecu - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Ford, Land Rover, Rover, Jeep, Jaguar, Rolls Royce Discussions. (https://mhhauto.com/Forum-Ford-Land-Rover-Rover-Jeep-Jaguar-Rolls-Royce-Discussions) +---- Thread: Ford Transit ABS fault U0401 invalid data from ecu (/Thread-Ford-Transit-ABS-fault-U0401-invalid-data-from-ecu) |
Ford Transit ABS fault U0401 invalid data from ecu - G256 - 05-29-2015 Hello, I have a Transit 2010 with ABS fault and ABS light is on: U0401 -Invalid data received from engine control module/powertrain control module -faulty signal -current I will check the wiring but has anyone ever had the error? Thanks in advance
Ford Transit ABS fault U0401 invalid data from ecu - mazolla - 05-29-2015 Hi "U" codes comes if moduls not right comunicate together,so check wireing and ground points. If are most ground points in the near of pcm. Put dem back from car body,clear it and put it back to car body. Check also the pins on Abs modul,fuses and relais in bjb. Many time it is wather in bjb,so be sure that bjb free from wather. After them try to update the moduls with newest callibrations data.Use Ford Ids for this job. Clear dtc's base and see what heppens. Good Luck RE: Ford Transit ABS fault U0401 invalid data from ecu - G256 - 06-02-2015 Can somebody please send me can bus wiring diagram for this car? Thanks in advance Ford Transit ABS fault U0401 invalid data from ecu - mazolla - 06-02-2015 (06-02-2015, 01:49 PM)G256 Wrote: Can somebody please send me can bus wiring diagram for this car? Sourche Ford Etis Software,install it and you have all data what you need . Good Luck RE: Ford Transit ABS fault U0401 invalid data from ecu - G256 - 06-03-2015 Hello, I tried, but can't install etis right now. (Error message). Please can somebody send me can bus diagramms for 2010 Transitr 2,4l Diesel. It's urgent. Thanks in advance RE: Ford Transit ABS fault U0401 invalid data from ecu - marcmu - 01-08-2016 (06-03-2015, 05:31 PM)G256 Wrote: Hello, hello, do you fixed this problem, i have same problem RE: Ford Transit ABS fault U0401 invalid data from ecu - G256 - 01-14-2016 Hello, no unfortunately don't fix this problem. RE: Ford Transit ABS fault U0401 invalid data from ecu - sazimam - 02-24-2016 (01-14-2016, 02:52 AM)G256 Wrote: Hello, Is there any DTC in PCM ? Whay diag tool do you use to pick up the DTCs? Had this problem on Kuga and solved withr new sensor on turbo vane actuator.
RE: Ford Transit ABS fault U0401 invalid data from ecu - sazimam - 03-01-2016 Is there some progress with this trouble ? Have you found another solution
