First Web Release: PKW Programming OFFLINE 2014 & 2015 - Printable Version
+---- Thread: First Web Release: PKW Programming OFFLINE 2014 & 2015 (/Thread-First-Web-Release-PKW-Programming-OFFLINE-2014-2015)
Pages: 1 2 3 4 5 6 7 8 9 10
First Web Release: PKW Programming OFFLINE 2014 & 2015 - pesona - 09-10-2015
hi,
this is a continuation story from Transporter OFFLINE, but this time the PKW..
I ask you to test it. If it is not okay, i will gladly to delete it.
it is okay with me because it help me killing time waiting.
Turn bored time to be an interesting one.
After this, i will look at imo and lkw. While for evobus, it is sad indeed.
Now not only the flash file, the evobus is removed from epc also. Fing20
here are the pictures, so you know what i mean
PROGRAMMING OFFLINE:
[attachment=93407] [attachment=93408] [attachment=93409]
[attachment=93410] [attachment=93411] [attachment=93412]
SCN OFFLINE
[attachment=93414] [attachment=93415] [attachment=93416]
[attachment=93417] [attachment=93418] [attachment=93419]
[attachment=93420] [attachment=93421]
here is the PKW Programming Offline & SCN Offline 2014
I test it using xentry 09-2014 simulation and I assume it can be used for 07-2014 & 12-2014 Xentry Version
NO PASSWORD
enjoy
Hint: Extract using latest winrar 5, copy to F:
[attachment=93426]
here is the PKW Programming Offline & SCN Offline 2015
I test it using xentry 07-2015 simulation and I assume it can be used for 03-2015 & 05-2015 Xentry Version..
if you find error(s) while using it in 03-2015 & 05-2015, try to use the PKW 2014 version
NO PASSWORD
enjoy
[attachment=93425]
MERCEDES SA CODE
[attachment=98911]
EDITED:
XDOS 64bit VERSION
No Password
Just run the exe file. It is rar file with sfx option.
Included in the archive akttab for pkw, so it will run without SDFlash CD mounted in the virtual drive.. I have simulated and hope you will get benefit of it.. enjoy
[attachment=98953]
EDITED:
Compiled from this thread added values from other members
pkw akttab added by maxbg
http://mhhauto.com/Thread-First-Web-Release-PKW-Programming-OFFLINE-SCN-OFFLINE-2014-2015?pid=544460#pid544460
added W204 in DAS added by laco210
http://mhhauto.com/Thread-First-Web-Release-PKW-Programming-OFFLINE-SCN-OFFLINE-2014-2015?pid=547604#pid547604
PKW OFFLINE INSTALL & REMOVAL added by macp
http://mhhauto.com/Thread-First-Web-Release-PKW-Programming-OFFLINE-SCN-OFFLINE-2014-2015?pid=552821#pid552821
EDIT:
Latest & 1st inbetrieb.ini that included W204 & X204 for offline programming..
use at your own risk
backup the original, extract the rar file and copy ini file to
Regular xentry winxp:
F:\programme\DAS\trees\pkw\flashen\ini
XDOS 32
C:\program files\mercedes-benz\DAS\trees\pkw\flashen\ini
XDOS 64
C:\program files (x86)\mercedes-benz\DAS\trees\pkw\flashen\ini
[attachment=107935]
TESTIMONIES:
(10-24-2015, 08:06 AM)maxbg Wrote: Here my results. I didn't actually click "Yes" because no time to wait but it successfully finds new software for control unit. So i believe it's working. I'll try to program later. And this with C3 mux.
(10-28-2015, 01:58 AM)macp Wrote: Thanks pesona!
I had an issue when I tried to login into Mercedes server for SCN coding session. It wouldnt allow access to the internet by way of DAS. I could access internet normally from desktop just not the way required for SCN where in DAS you choose to do SCN and Mercedes web login opens.
I figured I needed to remove your pkw hack. So I made self extracting files to install the 2015 and 2014 versions.
I also made 2 removal files that actually restores all the original files not just the altered files.
These will restore all folder to original for versions 07/2014 & 09/2015.
(11-26-2015, 10:05 PM)compan Wrote: I jus want to say thanks for pesona,very good job,today i was try xentry 09 2015 offline programming,programming was succesuful gearbox
(12-06-2015, 04:44 AM)diesel.lee Wrote: Just some positive feedback here, I have had success reflashing right front door module on S Class W221 that had become corrupt leaving right front window not working, Reflashed module offline and module is restored back to life I'm using 09/2015 Xentry with C4 SD Connect and 2014 flash data from 1st post. I must try to reflash engine ECU offline now.
Kind Regards
Lee
RE: First Web Release: PKW Programming OFFLINE & SCN OFFLINE 2014 & 2015 - bang won wook - 09-11-2015
Installing this program will scn offfline possible ?
RE: First Web Release: PKW Programming OFFLINE & SCN OFFLINE 2014 & 2015 - kamaleon - 09-11-2015
(09-11-2015, 07:46 AM)bang won wook Wrote: Installing this program will scn offfline possible ?
011 Movie
http://mhhauto.com/search.php?action=results&sid=5ab23361b5597259a2d1f16ff0f40e12
Kolo
Hi you bang won wook, WELCOME MHH
Time
Start here in forum sir in you first post, enjoy
http://mhhauto.com/Forum-Introduce-Yourself
http://mhhauto.com/Announcement-Forum-Rules
RE: First Web Release: PKW Programming OFFLINE & SCN OFFLINE 2014 & 2015 - pesona - 09-11-2015
As I said above, it is supposed to. Please look at the pictures. At minimum it will give you programming offline.
Inebetrib.ini file only is not functional since medio 2014 xentry release
Try it and give feedback
Btw, please do what a moderator ask you to do.
RE: First Web Release: PKW Programming OFFLINE & SCN OFFLINE 2014 & 2015 - pesona - 09-21-2015
For the 2015 version, I have simulate it with 09-2015 version, and it is okay.
RE: First Web Release: PKW Programming OFFLINE & SCN OFFLINE 2014 & 2015 - schou - 09-30-2015
Report: The PKW OFFLINE 2015 works for my 09/2015 DAS
Thanks for your great job !!! Fing32Fing32Fing32
[attachment=95929]
RE: First Web Release: PKW Programming OFFLINE & SCN OFFLINE 2014 & 2015 - pesona - 09-30-2015
Nice mate.
But i really appreciate if you tried it in real work and give feedback...
anyway, thanks for your nice comment and success with your work
RE: First Web Release: PKW Programming OFFLINE & SCN OFFLINE 2014 & 2015 - Jur - 10-01-2015
I need solution for sprinter w906 OM651 offline programming,please help me.
09/2014 das only Online prog.
Thanks!
RE: First Web Release: PKW Programming OFFLINE & SCN OFFLINE 2014 & 2015 - pesona - 10-01-2015
(10-01-2015, 12:23 PM)Jur Wrote: I need solution for sprinter w906 OM651 offline programming,please help me.
Thanks!
Hi, try the solution for transporter here
http://mhhauto.com/Thread-First-Web-Release-Transporter-Programming-Offline-SCN-Offline-2014-2015?pid=523029#pid523029
For your 09-2014 xentry, Use the 2014 version
And for your van, edit the inbetrieb.ini and add. If you can't, I will add it tonite.
And please give feedback
