StarFinder on Win 64 bit - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: StarFinder on Win 64 bit (/Thread-StarFinder-on-Win-64-bit) |
StarFinder on Win 64 bit - JRUMMAN - 10-02-2015 STAR Service Manual Libraries on CD and DVD Workaround for Compatibility Issues with 64-Bit Version of Windows Vista and Windows 7 GETTING YOUR CD or DVD to WORK with 64-Bit This also applies to CDs/DVDs that are not listed as being compatible with Windows Vista and Windows 7. Step 1 The first step is to prevent the WHIP! application from starting. This is possible by adding an "Autodesk WHIP!" key to the Windows Registry. This will prevent the WHIP! application from installing, which prevents program start when canceling. Continue to Step 2 to enable access to wiring diagrams. Step 2 Go to the Autodesk web site and download Design Review software. Click to Link to Site. http://usa.autodesk.com/adsk/servlet/pc/index?id=12423405&siteID=123112 Installation instructions: Step 3 Because of the now missing Autodesk WHIP! Plug-in, the wring diagrams on CD/DVD are inaccessible. The workaround for this is a separate "ETM Viewer" application that uses Autodesk Design Review and updated wiring diagrams. Get the required files: - Unpack the ETMviewer/zip and webetm***.zip files. - Move the "webetm"folder and "start.html" file into the empty "ETMviewer/webetm" folder. If this help you do not forget to click on thanks and + RE: StarFinder on Win 64 bit - JRUMMAN - 10-02-2015 her also you can get DesignReview browser add-on RE: StarFinder on Win 64 bit - JRUMMAN - 10-10-2015 Sorry all , I forget to add the STAR_ServiceManual_x64 reg file which mentioned above . if I help you click on thanks and rep+ RE: StarFinder on Win 64 bit - JRUMMAN - 12-01-2015 For Internet explorer new Ver do not forget: edited the file checkbrowser.js in the webetm\common directory. This is the line to edit: aValidBrowserVersions["MSIE"] = 11.0.4; Also you need to click "allow blocked content" RE: StarFinder on Win 64 bit - Dollsburg - 10-23-2016 Hi guys, I have installed Xenty Das 01/2014 With Das and Simdas Shortcuts, wis standalone, EPC, SD Media and everything is running fine but good old classic STARFINDER JUST CANT RUN! I keep on getting VB00016.DLL missing then OC25.dll missing. I downloaded them, saved them to the application destination folder, then in C:/Windows/System32 and added them to registry via regsvr32 <filename.extension> in cmd! But Today this starfinder just cant work?????????!!!! |
