Mercedes ECO Disable - Printable Version
+---- Thread: Mercedes ECO Disable (/Thread-Mercedes-ECO-Disable)
Mercedes ECO Disable - Darren G - 10-14-2015
Is there a way within DAS/Xentry to permanently turn off the ECO function, I find the whole stop/start thing annoying.
I know you can just hit the button to turn off everytime you start the car, but would rather not have to.
RE: Mercedes ECO Disable - Aless91 - 10-14-2015
What car? Normally remove it in CGW or in EIS depends on car or invert function in engine ecu.
RE: Mercedes ECO Disable - Darren G - 10-14-2015
SLK200 R172 2014
RE: Mercedes ECO Disable - Anturage - 10-17-2015
In engine ECU there is an option to make START\STOP be deactivated by default. To activate just hit ECO button.
RE: Mercedes ECO Disable - vmax - 06-13-2016
(10-14-2015, 09:18 PM)Aless91 Wrote: What car? Normally remove it in CGW or in EIS depends on car or invert function in engine ecu.
CGW_212 Stop/Start Automatic set to not available?
RE: Mercedes ECO Disable - CrAckJAck - 06-13-2016
maybe you can choose in the engine ECU "Last mode"
RE: Mercedes ECO Disable - wumpyr99 - 06-20-2016
Can you please explain the purpose of the invert function? I tested this setting in BC_F222 and it just inverts the ECO button status, on=off, off=on. How is this setting useful?
RE: Mercedes ECO Disable - Theo82 - 06-20-2016
(10-17-2015, 01:07 AM)Anturage Wrote: In engine ECU there is an option to make START\STOP be deactivated by default. To activate just hit ECO button.
I have tried it at w204 but its not working.
RE: Mercedes ECO Disable - Crosshair - 06-27-2016
Hello,
I have the same Problem.
I've set CRD3 to Last Mode on an S204 C220CDI BE OM651 but it wont't work.
If I set Start-Stop disabled on CGW the Eco indicator on Speedometer will disapear and Eco is completely switched of.
Is there any chance to set Last mode, by setting another system oder parameter???
Thanks in advance.
Cross
