Engine rattling when engaged to D or R - Printable Version
+---- Thread: Engine rattling when engaged to D or R (/Thread-Engine-rattling-when-engaged-to-D-or-R)
Engine rattling when engaged to D or R - Geniusman - 11-02-2015
hi members
i am still facing a problem with my 211041 car
i have a shaking problem when engage in D or R position
i replaced then engine and gearbox mountings but still have a problem
when putting the selector in N or P rattling stops immediately and RPM rises abnormally
i checked the idling RPM in D and it is as specified
No faults in engine or transmission modules
thanks for
advice and help
RE: Engine rattling when engaged to D or R - prof.memet - 11-02-2015
check gear oil temp sensor
Regards
RE: Engine rattling when engaged to D or R - Dollsburg - 11-02-2015
Check the Serpentine belt tensioner! Just remove the belt and cranck the engine and repeat your test!
RE: Engine rattling when engaged to D or R - darren_harper - 11-03-2015
Is it an automatic gearbox? Does the car kinda jerk forward when you put it in D?
RE: Engine rattling when engaged to D or R - benztech823 - 11-03-2015
There is a one way clutch internal to the alternator pulley that goes bad and causes the belt tensioner to rattle when in gear. The noise will likely change frequency or even go away if the A/C is switched off while in gear. If you take the belt off and hold the alternator shaft the pulley should lock one way and free wheel the other. If its locked both ways replaced the alternator pulley.
RE: Engine rattling when engaged to D or R - Geniusman - 11-03-2015
(11-03-2015, 03:43 AM)darren_harper Wrote: Is it an automatic gearbox? Does the car kinda jerk forward when you put it in D?
Automatic Transmission
Yes you got itTup
this is exactly the caseNod
(11-03-2015, 07:36 PM)benztech823 Wrote: There is a one way clutch internal to the alternator pulley that goes bad and causes the belt tensioner to rattle when in gear. The noise will likely change frequency or even go away if the A/C is switched off while in gear. If you take the belt off and hold the alternator shaft the pulley should lock one way and free wheel the other. If its locked both ways replaced the alternator pulley.
I will check it
(11-02-2015, 10:59 AM)Dollsburg Wrote: Check the Serpentine belt tensioner! Just remove the belt and cranck the engine and repeat your test!
ok will check it dear
RE: Engine rattling when engaged to D or R - darren_harper - 11-04-2015
Your problem is more than likely going to be the torque converter located inside your gearbox...
RE: Engine rattling when engaged to D or R - makaron9999 - 11-05-2015
(11-02-2015, 01:46 AM)Geniusman Wrote: hi members
thanks for
advice and help
Hi. Swap the fuel injectors
RE: Engine rattling when engaged to D or R - Geniusman - 11-06-2015
hi dears
the problem was dirty valve body...after cleaning it improved almost 85%..am going to replace the hydraulic pump of steering and the steering shaft..
any word of help was immensely helpful
thanks
