DAS 09/2010 mystery? - Printable Version
+---- Thread: DAS 09/2010 mystery? (/Thread-DAS-09-2010-mystery)
DAS 09/2010 mystery? - ssinlandstar2 - 03-12-2011
I have had no luck installing 09/2010 das even though the setup completes successfully. My problem is so far is the das & das sim shortcuts in the start menu do not work. also symantec anti-virus never installed either. my half solution at this point was to manually modify the das shortcut from "C:\Programme\Cobra\DblDlm\Login2.bat XD EN" to "C:\Programme\DAS\bin\DAS32R2.exe".
However when i modify the das sim to C:\Programme\DAS\bin\simdas.exe from I get an error, No language defined!
Anyone bumped into this problem?
I've exhausted my efforts to look around the forum and the web to no avail.
-ssinlandstar2
RE: DAS 09/2010 mystery? - weryo - 03-12-2011
install DAS again!
...and shortcuts will work!
by the way on the forum is written about these shortcuts!
RE: DAS 09/2010 mystery? - ssinlandstar2 - 03-13-2011
(03-12-2011, 10:57 PM)weryo Wrote: install DAS again!
The Wise Weyro, your solution worked flawlessly.
