problem SD Connect - Printable Version
+---- Thread: problem SD Connect (/Thread-problem-SD-Connect--73211)
problem SD Connect - vanadzor - 11-08-2015
help me please
SD connect 4 car battary 32v --> realy 13v
problem 1.2-2.503.9901 Update.... and not finish
as it can be to get up?
RE: problem SD Connect - anonimo - 11-08-2015
In case of problems reset the SDConnect and change firmware inside.
RE: problem SD Connect - Anturage - 11-08-2015
At least "32v --> realy 13v" means hardware malfunction.
Firmware could not resolve hardware failure.
It's died as most of china fake.
RE: problem SD Connect - vanadzor - 11-08-2015
(11-08-2015, 04:06 PM)Anturage Wrote: At least "32v --> realy 13v" means hardware malfunction.
SDconnect external voltage too low. (646)
You will get this screen if attempting update firmware.
Toolkit check outside and battery voltage and refuses if voltage is out of range.
RE: problem SD Connect - mixx0108 - 06-09-2016
Hi,
I have this problem too. Someone have solution?
RE: problem SD Connect - jointdmc - 01-06-2017
My C4 have problem, aren't I?
[Image: binh_ac_quy.png]
