Xentry OpenShell EPC and WIS Problems :( - Printable Version
+---- Thread: Xentry OpenShell EPC and WIS Problems :( (/Thread-Xentry-OpenShell-EPC-and-WIS-Problems)
Xentry OpenShell EPC and WIS Problems :( - armaniboy2711 - 11-15-2015
Hey friends,
I have the following problem, I have the Xentry open shell completely installed 09-2015 and 06-2015 with EPC and WIS update 09-2015 10-2015.
Now to my problem:
when I open Xentry and afhrzeug select them and read all works ...
only when I want to open the left side of the xentry the EPC or WIS then he tries for a website to be opened by Mercedes-Benz since only these catalogs online are where.
Which file should I edit, and how or what I need to be in there writing the EPC and WIS, it opens by computer with java ???
as I said, the problem with EPC and WIS is only in Xentry.
I open the 2 shortcuts on the desktop it opens quite normal .....
P.S. would like to thank DieTRih especially thank you for your help top up now.
Once I managed all this I'll create a Imgae with Acronis and the Board upload course Smile
the good it's all been created on a German Windows 7 Ultimate with everything in German as well as a Panasonic CF-52nd
Thus, also compatible with other Panasonic models and Dell's
RE: Xentry OpenShell EPC and WIS Problems :( - Bibobabo - 11-15-2015
Try to open WIS/EPC first and don't close. After that start Xentry and try open WIS/EPC with buttons on left side again. With old xentry this works for me. Hope this helps you, too.
RE: Xentry OpenShell EPC and WIS Problems :( - armaniboy2711 - 11-15-2015
but that is not a good solution in my opinion. and there have tried it not work for me since he wants to get the online services of Mercedes ...... somewhere it is written back to a file where you have to change it Sad
okay i have found it under C:/program Files x86/Mercedes-Benz/ AppServ
can (51) and (101) under the name EPC and WIS call directly through java Sad but I still do not know how I
have all tried from left to Properties of a shortcut on the desktop, etc. but I did not get it Sad
maybe there's one of knows how
RE: Xentry OpenShell EPC and WIS Problems :( - Yudi - 11-15-2015
(11-15-2015, 09:53 PM)armaniboy2711 Wrote: okay i have found it under C:/program Files x86/Mercedes-Benz/ AppServ
you already on correct target sir.. Big Grin
but you can change it with url : localhost\ .....do
that will direct you.. to ewanet login
good luck
regards
Hi Yudi
Thank you for your quick response Smile
I know I have everything already tried and everything it works well only I want it once in xentry the EPC or WIS open directly start the program as in the old version 2014 without open shell I.
because it works so well and the vehicle is then called directly with the vehicle data.
Tells you what I mean?
Yudi,
I can not just in "url" there enter a command so that is then started directly the EPC?
practical as a autorun or a direct link to it?
That has to sien feasible, but I am familiar with autorun or AUTOEXEC.BAT not so good or Skrypt to write it then directly about the epc starts without until the ewanet to open earlier
RE: Xentry OpenShell EPC and WIS Problems :( - Rennbenz - 11-13-2016
Hello,
I also get EPC and WIS not started. I have Java installed. In the EWA Net Admin Tool everything is OK. But when I open EWA Net, I have there also no icons. Also not on the desktop.
Does somebody has any idea?
thank you
RE: Xentry OpenShell EPC and WIS Problems :( - autoseek - 11-14-2016
(11-13-2016, 04:38 AM)Rennbenz Wrote: Hello,
thank you
When this happened to me, it was a problem with the Startkeys: I had turned off the Wifi adapter, and that somehow changed the Ewanet ID.
RE: Xentry OpenShell EPC and WIS Problems :( - carlo - 11-14-2016
(11-15-2015, 01:11 AM)armaniboy2711 Wrote: Hey friends,
Now to my problem:
Sir, do you want to have Wis standalone which link from DAS and Xentry?
