suzuki sdt2 vci - Printable Version
+--- Thread: suzuki sdt2 vci (/Thread-suzuki-sdt2-vci)
Pages: 1 2 3 4
suzuki sdt2 vci - mustang - 05-12-2016
hello mates,
I am looking for the suzuki SDT2 software that uses a BOSCH (blue) vci interface.
I have a ford/mazda VCMII made by bosch, its a clone, but works perfect on those vehicles.
I strongly beleive that this VCMII its exactly the same as the suzuki dst2 vci, but I need the software to try it out.
I already have the VCI driver that configures the VCMII, all I need now its the software to test it.
Can someone point me in the right direction?
I will post all results as usual at this forum..
thanks mates.
cheers..[attachment=127990]
RE: suzuki sdt2 vci - waiky - 05-12-2016
(05-12-2016, 05:00 AM)mustang Wrote: hello mates,
thanks mates.
cheers..
You only need to search in the Forum, you will get almost all information that you need.
I hope this help to you:
http://mhhauto.com/Thread-Suzuki-Smart-Diagnostic-Tester-II-SDT-II-v2-9-0-47-10-2015-Multilanguagehttp://mhhauto.com/Thread-Suzuki-Smart-Diagnostic-Tester-II-SDT-II-v2-9-0-47-10-2015-Multilanguage
Good Luck!!!049
RE: suzuki sdt2 vci - mustang - 05-12-2016
thanks mates.
cheers..
Good Luck!!!049
any idea if this software is available in MEGA ? t
thanks ...
RE: suzuki sdt2 vci - biker350 - 05-14-2016
(05-12-2016, 08:26 AM)mustang Wrote: any idea if this software is available in MEGA ? t
thanks ...
Can you share a driver configuration / driver please?
Also have you tried it yet?
RE: suzuki sdt2 vci - mitko_1 - 05-14-2016
Tested work with Ford VCM II 100% .
link in Mega : https://mega.nz/#!gAEjhZ4Z!tMN6gQ0REmasyr4nvLcgJnAkQOT9NaWk9Wm0gOexLVo
best regards
RE: suzuki sdt2 vci - ukge4122 - 05-16-2016
(05-14-2016, 09:38 AM)mitko_1 Wrote: Tested work with Ford VCM II 100% .
best regards
Do you have to configure the Ford VCMII or will it work automatically? This is an original Ford VCM II
Will i need to reconfigure the Ford Adapter if I need to connect to a Ford vehicle afterwards?
RE: suzuki sdt2 vci - meiguang - 06-14-2016
best regards
yes working automatically after change your vcm2 registry to suzuki registry and copy folder from vci vcm2 to vci suzuki
Good luck Tup
RE: suzuki sdt2 vci - mustang - 07-16-2016
this is how I made it work with the suzuki sdt2 software.
I used the cheapest FORD VCMII clone from china....yep..the cheapest $ 120.
I used a dell latitude d630 with clean install windows 7 32 bit professional.
I installed the FORD V.86.
I opened the Bosch VCI manager and updated the VCM II to work with ford v86.
I installed suzuki sdt2 software, and when the install asked me to connect the VCMII i connected the FORD VCM II and continued with the install.
Once it finished I opened the BOSCH folder, then VTX-VCI sub folder, and copied the entire contents of the VCI Software (Ford-VCM-II) to VCI Software (6516-Suzuki). Replace all files !!!
the suzuki software will see the VCMII as the OEM VCM even that the VCI manager say its a FORD VCMII.
The regedit will look into the folder VCI Software (6516-Suzuki) for all the drivers, and it will load the FORD drivers to make it work.
DONE.
Remember to open VCI manager and connect the VCM before you go into the suzuki or ford software.
I hope this helps !!
Please contribute to this wonderful site!!!
Remember to give thanks...
cheers..
RE: suzuki sdt2 vci - mustang - 08-21-2016
I confirm that the ford VCMII works perfectly with suzuki DST2 software.
I connected a 2015 car non USA model and worked perfectly.
I also connected other USA model cars and worked OK.
Cheers.
