VPO -12 error? - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: VPO -12 error? (/Thread-VPO-12-error) Pages:
VPO -12 error? - 93r1 - 05-24-2016 Error when online coding VPO -12 Any ideas. Yudi is not available apparently
RE: VPO -12 error? - danrad - 05-24-2016 Which version of star do you used. RE: VPO -12 error? - 93r1 - 05-24-2016 7/2015 with vpo - 5 fix RE: VPO -12 error? - Rocinante - 05-24-2016 You need the profi_cd.ini for a newer release, what is it PKW? Here is the guts from my 05/2016.. [DEFAULT] DAS-CD-NR=05/2016 (2016-03-16) FlashData=2016.05.011 CAESAR-NR=03.01.99 MVCI-NR=08.02.026 RE: VPO -12 error? - danrad - 05-24-2016 Just transfer the file to the folder. And will work RE: VPO -12 error? - 93r1 - 05-24-2016 Just the file in the PKW folder need modified? Will try that now... RE: VPO -12 error? - mickmaicol - 07-07-2016 Just change pkw? Or you have to make all the folders? RE: VPO -12 error? - MBstar78 - 07-07-2016 Profi_cd.ini Just transfer it with replacement RE: VPO -12 error? - stealth - 08-22-2016 I have same mistake and tried to replace it and nothing happened... Fixed it with your advice, in Smart folder |
