Turn off Prem Air sensor with Vediamo/Monaco - Printable Version
+---- Thread: Turn off Prem Air sensor with Vediamo/Monaco (/Thread-Turn-off-Prem-Air-sensor-with-Vediamo-Monaco)
Pages: 1 2 3
Turn off Prem Air sensor with Vediamo/Monaco - Rocinante - 06-09-2016
Anybody got a way to turn off the damn Prem Air sensor with Monaco?? or Vediamo (I can install it if needed but have Monaco ready to go)..
Its a 212 with a 276 engine. If you need more specific control unit info I can get it tomorrow, but this is maddening. We have replace the sensor, radiator, anther sensor, fuel computer and thoroughly checked the harness..
RE: Turn off Prem Air sensor with Monaco - HestonDiag - 06-09-2016
I have never worked on Prem Air sensors so please excuse me if my reply is not relevant to you.
However I've just done a little reading that shows this is to monitor the Prem Air coating on the radiator is effectively converting ozone in atmosphere back to oxygen.
I read of one case I think on a W211 where someone had aftermarket HID's (which were found to have damaged capacitor on one side) leaking AC into the car's DC power supply which damaged the regulator on the alternator and prem air sensor.
If you do feel like having one last bash at this car, maybe worth scoping terminal 15/30 so see how dirty they look and compare to a good car if posisble, and maybe even to externally power the sensor from a known clean source (but would need to join earth of external source to car's earth for this to work).
RE: Turn off Prem Air sensor with Monaco - Rocinante - 06-09-2016
Thanks for the reply, I'm not working on the car one of my co-workers is, so I will pass this info along Smile
RE: Turn off Prem Air sensor with Monaco - Rocinante - 06-11-2016
How about Vediamo? Can someone tell me the term to turn it off?
RE: Turn off Prem Air sensor with Monaco - rashid - 06-11-2016
Although ive never done it but 99% it can be
But you will need to calculate seed key
And than only you can change coding
I thought if I went into the control unit like I was going to update the SCN coding, that would unlock it to perform the change?
RE: Turn off Prem Air sensor with Monaco - HestonDiag - 06-12-2016
I am not 100% sure, but I just took a look at ME97.CBF as Xentry simulation seems to suggest 212059 will have ME97 ECU.
If I look at variant coding, under Implicit_Coding_ME97, there is an option:
Prem-Air-System, Prem-Air-System verbaut and Prem-Air-System nicht verbaut.
That looks like what you need to change.
However I cannot find any SG_Entriegeln type commands that we normally use to unlock ECU to allow changes to be made.
All I can find in both is
SEC_SecurityAccess_GetSeedLevel1
SEC_SecurityAccess_GetSeedLevel3
SEC_SecurityAccess_SendSeedLevel1
SEC_SecurityAccess_SendSeedLevel3
It may be the case that you are able to change this parameter without unlocking the ECU. If you do need to unlock it, it looks like the proper technique would be to generate seed key. I have a feeling your idea about starting update may unlock it, but I am not sure to be honest - if that is the trick I would be most pleased to find out.
RE: Turn off Prem Air sensor with Monaco - Rocinante - 06-12-2016
Thanks, I was wrong.. its a 212056 with a 272 engine but it does have ME97.
I will have to do some poking around and report back.
Thanks for the info!
RE: Turn off Prem Air sensor with Monaco - webmaster - 06-12-2016
Never did it before but as I know if u have another SAME car type in workshop that doesn't have this option, u can apply its software (Coding) on the other car by vediamo...
Correct me if I'm wrong 533
Best regards.
