Throttle stop adaptation problem - Printable Version
+---- Thread: Throttle stop adaptation problem (/Thread-Throttle-stop-adaptation-problem)
Throttle stop adaptation problem - Geniusman - 06-27-2016
Hi mates
i have a W 20202 had a problem with actuator..i replaced the actuator with new one
the idling improved so much but the throttle stop not programmed
there is no option in the adaptation menu rather than BOOT STRAPPING so i can lean the throttle stop
i erased all the date and tried to adapt but the actuator not learnt and the menu quits
the car doesn't start because of this any more
i tried second time but this message appeared with failure of adaptation
Programming conditions not met see diagnosis manual engine vol 4 index 9.1-6 Conditions for programming.
the actuator make sound like buzzing while tring to adapt
Help appreciated
RE: Throttle stop adaptation problem - Geniusman - 06-28-2016
Some help mates
RE: Throttle stop adaptation problem - alexjx - 06-28-2016
maybe a complete vin can help?
(06-28-2016, 04:44 AM)alexjx Wrote: maybe a complete vin can help?
Tomorrow i will post the VIN
it is 202 engine 111 model 99/2000
eh?this is the one with airmass,right?
and the actuator is connected with a rod,pulled by cable,rite?if yes, try this method and see.
remove the rod at the actuator. then bootstrapping again.
during learning, the actuator will slowly go to max, and return to position.
No this one with electronic pedal and the actuator is without a Rod (electronic)
hm...
maybe we need some screen shots of some actual values.
idle actual value:Is the idle contact "on"?
what about coolant temperature?is it at "-" ?
any special fault codes?
RE: Throttle stop adaptation problem - Rocinante - 06-28-2016
You can try and do the auto throttle actuator learn by just leaving the key in position 2 with the engine off for a couple of minutes..you will see and hear the actuator move to the end position then return... if it does this, then its learned and you don't need the sds as there might be a software bug in the learning process..
RE: Throttle stop adaptation problem - vanos batam - 06-28-2016
Make position zero on the screw thortle then adap with star
