skoda octavia 1 / golf 4 can gateway location
Hi all . Please somebody can tell me if for skoda octavia 1 / golf 4 exists separatly can gateway module or it is inserted in instrument cluster or ecu?
Another question is for next situation. One of my firends made a 4X4 car from FWD car and he mounted the abs module and haldex module. We put can L and can H wires from abs module one the can L and can H from ecu wires whitch go to instrument cluster somewhere at 30cm from ecu and the haldesx wires can L and can L whitch had 3meters lenght directly in instrument cluster can h and can l pins of its connector. On VCDS we have some times good conection and diagnose for abs and haldex module and after some times connection lost.
Must put some resistance on the can wires? But i don't have open circuit , all modules are inside the circuit.
If anybody had an ideea please tell me.
Many thanks in advance.
gateway is in the cluster. recode 19 with the same code that is in it now (i think 6) this will refresh the gateway installation list, and maybe fix your problem. i think for diagnosis you still need a k line on this car.
Thanks given by: tao13
(11-26-2020, 04:51 PM)Michel R32 Wrote: gateway is in the cluster. recode 19 with the same code that is in it now (i think 6) this will refresh the gateway installation list, and maybe fix your problem. i think for diagnosis you still need a k line on this car.
abs is connected with kline too, only haldex not connected kline wire but will do.
thanks and i'll try to recoding
04-23-2026, 08:53 PM
04-23-2026, 08:39 PM
Skoda
04-10-2026, 06:47 PM
