  • 52 Vote(s) - 4.77 Average
ISTA 4.39.20 STANDALONE ON MEGA (LICENSE ACTIVATED)
(04-01-2023, 01:45 PM)modernm69 Wrote:
(02-28-2023, 01:06 AM)Sauron Wrote: LICENSE FREE
LANGUAGES; ENGLISH, GERMAN
PM FOR PASS AFTER REP AND THANKS
Many Thank. Password pls.
(04-28-2023, 04:47 PM)Kuni78 Wrote: I get the error If I want to identify the car
"The programming system could not be initialized. The ISTA installation may be corrupt or misconfigured. Reinstall ISTA. If problems persist, contact local support."
does anyone have a solution?
clear registries and do a fresh install.
Thanks given by: benlodite
11
(04-27-2023, 05:25 PM)Sauron Wrote:
(04-27-2023, 01:26 PM)werso77 Wrote: does this work with sdp 4.40.50 ?
You may extract 4.40 to data_swi folder, then change version in registry file and execute
Where do you change the version of the newer SWI files in registry? Is it here?:
[HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\BMWGroup\ISPI\ISTA]"DataVersion"="4.39.20"
"LogisticBaseVersion"="4.39.20"
"DataVersion_de-DE"="4.39.20"
"DataVersion_en-GB"="4.39.20"
"SWIData"="4.39.20"                        <-  only here or anywhere else??  Enter here the version of the newer SWI?
What is the AppCheckDisable registry file for? This is not for use of different SWI files?  I thought just copy the newer SWI files..?
Thank you!
12
I have exactly the same issue and can't find a solution.
Maybe someone can help.
(05-10-2023, 04:58 PM)Altiman Wrote: hi,i install it when try read car,just start to get info and not much.I see ICOM in device id.All is look ok but cant read car,any idea wheree is problem?
I got the exactly the same problem. Maybe someone can help.
Thanks in advance.
[quote pid="2543449" dateline="1683741486"]
Thanks in advance.
[/quote]
install all prerequisite.
try also enet for F serie.
post a screenshot how looks
(05-11-2023, 06:02 PM)Altiman Wrote:
(05-11-2023, 02:50 AM)Sauron Wrote: [quote pid="2543449" dateline="1683741486"]
Thanks in advance.
When i select "Read Out Vehicle Data " thinking and open connection manager,i see ICOM and when press "Set up connection"  thinking and back to "Read Out Vehicle Data".Thats it,like i say look all is ok but cant connect to vehcile.I try E and F series same.
[/quote]
i think installation is not good
(05-13-2023, 09:34 PM)F32WINS Wrote: Hello, thanks again for the great stuff and work - installed and works perfectly. Just a quick question (sorry if it got asked already I perhaps missed). Is there anything special that needs to be observed when wanting to update with latest DELTA FILES? I suppose I have to go step by step and version by version correct? I mean 4.39.25 Delta would be needed before being able to update to 4.39.30? Thanks for your feedback.
Updating from standalone with delta files would require launcher console. And keep in mind that the application is not updated, only BLP and SDP
Thanks given by: F32WINS
16
how to remove ista low battery warning?
Thanks in advance.
Same thing with kdcan cable do you find problem ? When I read the vehicle nothing happens.
[/quote]
first make sure if kdcan works with inpa. Then test with ista. Select ediabas in settings.
did you install c++ libraries?
Sazki
10 hours ago
06-14-2026, 10:28 PM
06-11-2026, 11:52 PM
