  • 56 Vote(s) - 3.18 Average
Thanks given by: daxxer , naseem__amg
hi
Its easy.. just take it from Comand then connect to pc. With any good tool for HDD yo can clone it.
BR
If you like it please click on REPUTATION and THANKS
Your best and safest (not fiddling with partition tables, possibly secret hidden information, just copy every single bit) bet would be any linux variant e.g. a live CD of Ubuntu or GParted.
To create an image file / backup you execute the following:
Code:
dd if=/dev/sdX conv=sync,noerror bs=2M | gzip -c  > /mnt/backup/hu_backup.img.gz
Where sdX is your connected COMAND HDD device name (like sdb, sdc, sdd; you can find out which one by executing "dmesg" after you connect your HDD with a SATA-to-USB converter) and your target partition where you want to put your backup file is mounted to /mnt/backup. Image will be gzipped to save space, and bad sectors will be skipped and filled with zeros just in case you have a failing COMAND HDD. Get a lot of coffee, it takes a looong time on USB 2.0 Smile (Think overnight.)
You restore the saved image to a new HDD using the following command:
Code:
gunzip -c /mnt/backup/hu_backup.img.gz | dd of=/dev/sdX conv=sync,noerror bs=2M
If cloning direcly (rather than in two steps: (1) to-a-file and (2) from-a-file) you can do the following:
Code:
dd if=/dev/sdX conv=sync,noerror bs=2M of=/dev/sdY
Where sdX is your old HDD and sdY is your new HDD.
Thanks given by: cocoh , r66r66 , bawarek , alex_ng
Here its someone which can share HDD image for NTG 2.5?
I might be able to but only in about three weeks' time when I come back from holidays.
HDclone Pro works really well
(07-25-2015, 11:53 AM)davidcie Wrote: I might be able to but only in about three weeks' time when I come back from holidays.
Took some time but saw the car again today and got round to copying the HDD. Took the NTG2.5 out of the vehicle, took out the HDD, took out my HDD-to-USB adapter... only to find out that the Toshiba 40GB HDD NTG2.5 uses is of the old PATA type while the adapter and none of five laptops and computers at home carries this interface anymore Headbang
So just a word of caution to anyone hoping to clone or restore their NTG2.5 HDD: please make sure you have something to connect it to before attempting your repair Smile
Thanks given by: cocoh , bawarek
up!!!!
need image hdd ntg 2.5 tohiba mk4036gac 40gb. thanks!
