  • 17 Vote(s) - 3.06 Average
07/14 - Xentry Error
Hi all
I seem to be having an issue with my installed 07/14 version, I've tried everything to resolve this but just can't seem to find the answer.
This is in simulation, this error appears on new models however if I launch into DAS all appears to be fine.
SDnetControl isn't running..
Thanks given by: Yudi
On this screen I killed it, exactly the same error with or without
It has to be running or Xentry won't work..
Take another screen shot with it running and see if the MUX icon is locked or unlocked..
(04-17-2016, 07:50 PM)Rocinante Wrote: It has to be running or Xentry won't work..
With it running, remember this is only simulation, does it lock out during this??
Not sure.. run a real diagnosis session and see if it communicates..
Still the same
hi i need help whit install xentry das xentry 09 2014 i try install
show error 5006 :0x80070015
thank
