Thanks Given: 800
Thanks Received: 67 (62 Posts)
1,363
522
Is it posible to program used transmission module on 2017 Chevrolet Silverado 5.3L?
Its Global Architecture electrical system so I understand normally can not be done , but anyway around this?
Thanks Given: 800
1,363
522
clone ioterminal could handle that?
Thanks Given: 800
1,363
522
basicaly used transmission was installed car now has just first gear and reverse
not sure if module is in tranny or somwhere out of it.
Whats the proces to make this car run properly?
383
Thanks Given: 813
Thanks Received: 893 (143 Posts)
340
40
I think HP Tuner help you.
Thanks Given: 101
Thanks Received: 57 (47 Posts)
328
131
Ummm hp tunners won’t help ,,, it won’t shift .
If u wanted to do it . U would need to know how to unlock .
Then un could change vin . Etc
18
Thanks Given: 274
Thanks Received: 90 (76 Posts)
535
29
I can do it remotely if the used tcm is compatible.
Pm me
