2018 peterbilt 579
Hello.
I have a 2018 Peterbilt 579 with a MX 11 EPA 17. The aftertreatmen module does not connect (using JPro)
Connector has 12 volts and GND. Any ideas?
One quick question if I test for ohms across yellow and green wires on tbe connector it should read 60 ohms right?
If you still need help,  find any oem aftertreatment harness sticker with part number on the truck. I will try to pull diagram for you.
Thanks given by: mrperkins
common problem on these
Faulty ACM
REMOTE DELETE SERVICE
File service for trucks, off-highway, agriculture
RAM 2022-2024 deletes available remotely !
(05-24-2026, 08:38 PM)hardy Wrote: If you still need help,  find any oem aftertreatment harness sticker with part number on the truck. I will try to pull diagram for you.
The part number for the ACM is
A054G093
Question, does it have to be programmed for the truck?
A054G093
Yes. needs to be reprogrammed to VIN, I can help you w that if you need
TUNING...
SOFTWARE...
ALL SORTS OF OTHER SERVICES...
MSG WITH ANY QUESTIONS HAPPY TO HELP!
Yesterday, 06:03 AM
05-28-2026, 05:16 AM
05-23-2026, 05:18 PM
