2018 peterbilt 579 - Printable Version
+---- Forum: Paccar Group (https://mhhauto.com/Forum-Paccar-Group)
+---- Thread: 2018 peterbilt 579 (/Thread-2018-peterbilt-579)
2018 peterbilt 579 - mrperkins - 05-23-2026
Hello.
I have a 2018 Peterbilt 579 with a MX 11 EPA 17. The aftertreatmen module does not connect (using JPro)
Connector has 12 volts and GND. Any ideas?
One quick question if I test for ohms across yellow and green wires on tbe connector it should read 60 ohms right?
RE: 2018 peterbilt 579 - hardy - 05-24-2026
If you still need help,  find any oem aftertreatment harness sticker with part number on the truck. I will try to pull diagram for you.
RE: 2018 peterbilt 579 - MaxEcu - 05-24-2026
common problem on these
Faulty ACM
RE: 2018 peterbilt 579 - mrperkins - 05-25-2026
(05-24-2026, 08:38 PM)hardy Wrote: If you still need help,  find any oem aftertreatment harness sticker with part number on the truck. I will try to pull diagram for you.
The part number for the ACM is
A054G093
Question, does it have to be programmed for the truck?
RE: 2018 peterbilt 579 - SwaeTech - 05-28-2026
A054G093
Yes. needs to be reprogrammed to VIN, I can help you w that if you need
