137
Thanks Given: 466
Thanks Received: 1031 (564 Posts)
1,265
Threads:
14
Hi!
I can help.....
Moin!
Ich kann helfen.....
137
Thanks Given: 466
1,265
Threads:
14
03-10-2017, 11:28 AM
(This post was last modified: 03-10-2017, 11:29 AM by Kaluluka.)
For Suggestion we need info from diagnostic: you have faulty hardware or software.
Session from diagnostic of IC will clarify whats wrong.
11
Thanks Given: 120
Thanks Received: 68 (51 Posts)
392
Threads:
65
dash file is faulty put other file all ok
82
Thanks Given: 399
Thanks Received: 434 (101 Posts)
260
Threads:
14
get a used one and be sure its the same part number and change eeprom
0
Thanks Given: 4
Thanks Received: 0 (0 Posts)
Threads:
03-11-2017, 12:34 AM
(This post was last modified: 03-11-2017, 12:27 PM by Vandale17.)
I can unfortunately the photo does not post does not work but in vediamo is:
KI221-BootV12E0 D602:ECU Application software Code 2 Is missing or is faulty
11
Thanks Given: 120
392
Threads:
65
with vediamo its hard do you have another dash put a file in it eveything will be ok
50
Thanks Given: 16
Thanks Received: 150 (53 Posts)
240
Threads:
13
03-12-2017, 11:50 AM
(This post was last modified: 03-12-2017, 11:51 AM by benzsport.)
Display is in bootmode.
Take Steuergeräteprogrammierung with DAS and flash the right files.
DAS Choice the right ones.
I can fix it too.
With Vediamo works great too, but you must know which files you need.
