  • 18 Vote(s) - 2.61 Average
722.6 issue
I have problem with my car. From 2 to 3 gear switch too late...on 2400rpm. From 3 to 4 gear switch on 2800 rpm. If I start the car and press gas pedal to 4000 rpm on Neutral position, then no problem...all is perfect to the next start. If not...i have very long switch.
I have friend with w210 too with 722.6 with the same problem...
From 2 to 3 - 2400rpm
From 3 to 4 - 2800rpm
Is that some famous problem?
assume fluid level and filter are ok , try to rest adaptation
Thanks given by: KG7222
Yes. New filer and oil and reset adaptation stll same.
i will try the transmission ecu
What about valve body?
gears changes softly?
No, the changes are very good, just on high rpm...and only from 2 to 3 and from 3 to 4
If I start the engine and press acelerate pedal to 4000rpm on P or N, then I have perfect changes like a brand new gearbox
manual mode also perfect?
Yes, the old oil was good too. Good red color. By the way the car is w202 2.2cdi 2000.
