62
Thanks Given: 251
Thanks Received: 253 (135 Posts)
566
154
11-11-2016, 09:20 PM
Hi,
So my problems today is:
MB w221 722.9 4x4 rise temp till 127 and maybe more, because gearbox wont run.
I checked other w221 but rwd and max temp is 99 100.
So this 127 it is normal or no? Because I read that temp fault appear only from 140.
453
Thanks Given: 444
Thanks Received: 1578 (376 Posts)
670
57
I would say normal operating temp = 90-110 Celsius
62
Thanks Given: 251
566
154
Where can be a problem? I tried to blow radiator but everything looks ok.
453
Thanks Given: 444
670
57
pressure? Broken oil pump?
62
Thanks Given: 251
566
154
Fluid is circling. So I think pump is ok.
453
Thanks Given: 444
670
57
what about rpm's inside trans? for temperature to rise and vehicle not moving - something must be slipping...
62
Thanks Given: 251
566
154
11-12-2016, 12:01 AM
(This post was last modified: 11-12-2016, 12:03 AM by salerka.)
When temp is till ~115 car is running, but when more its looks like torque converter problem. Gears is jumping to N, car stop runing, converter shows (Open-->Slipping) end ect. Need to turn ignition off, wait few minutes and car runs again bit.
I got this fault only on hot:
0894: The Gear is Implausible or the Transmission is Slipping.
130
Thanks Given: 967
Thanks Received: 295 (46 Posts)
94
16
if you do not change the filter in the gearbox replaced it. mesh can be clogged in the valves clean your grid.
452
Thanks Given: 914
Thanks Received: 2148 (1269 Posts)
2,513
26
Have you checked all your upshift/downshift adaptations?? You might find your problem there. Have you checked fluid? Any metal in the pan?
