(06-22-2025, 05:07 AM)ZooperDooper Wrote:Just checked, still blocked without a vpn. Most of the dealers here are still operating, but they have other brands as well(06-22-2025, 04:25 AM)Gmguy Wrote:(06-22-2025, 02:55 AM)ZooperDooper Wrote:(06-22-2025, 02:25 AM)Gmguy Wrote: I use a vpn all the time as they region blocked my country New Zealand, also use my NZ bank card to pay without issue.
I did get banned for using a clone tool at one point but after a chat to helpdesk they unlocked my account even after giving them a NZ area code for call back lol
They region blocked NZ ??? That was part of the Holden network and should not have been blocked as it is considered part of the Australian network for GM.
Yeah its been region blocked for as long as I have been using it. We dont have right to repair laws here so everything is locked down to dealer only from pretty much every brand, even service info.
I think you will find SPS has unblocked NZ since Holden went out of business because I know other people using it in NZ and never been banned.
[email protected]
ACdelcoTDS disabled account
20
06-22-2025, 06:20 AM
(06-22-2025, 05:10 AM)Gmguy Wrote:(06-22-2025, 05:07 AM)ZooperDooper Wrote:Just checked, still blocked without a vpn. Most of the dealers here are still operating, but they have other brands as well(06-22-2025, 04:25 AM)Gmguy Wrote:(06-22-2025, 02:55 AM)ZooperDooper Wrote:(06-22-2025, 02:25 AM)Gmguy Wrote: I use a vpn all the time as they region blocked my country New Zealand, also use my NZ bank card to pay without issue.
That is interesting.
I know they are running Cloudflare warp which is free and WAN DNS 1.1.1.1 and 1.0.0.1 which bypasses a lot of crap so I wonder if that is why.
21
06-22-2025, 08:29 AM
(06-22-2025, 06:20 AM)ZooperDooper Wrote: That is interesting. I know they are running Cloudflare warp which is free and WAN DNS 1.1.1.1 and 1.0.0.1 which bypasses a lot of crap so I wonder if that is why.
Yeah i dont know about any of that, but there must be a link that does redirect or work from NZ for the dealers to use as I cant see them manually adding ip exceptions for each dealer as it would take a lot of time and most places probably have dynamic ips not static
22
06-22-2025, 04:52 PM
(06-22-2025, 02:12 AM)ZooperDooper Wrote:(06-22-2025, 01:13 AM)Dezzz Wrote:(06-19-2025, 04:29 PM)Tek1229 Wrote: This is the utility file for 2012 IPC.. Far as I know it's worked on all the truck ipc's from 2007-2013
Thanks again Tek for this utility file, I have made some attempts to build an archive with DPS and program a cluster but DPS always returns an error. Im using the calibration files located at this repository https://github.com/vampperformance/cals/tree/main
Do you or anyone have an opinion on what my be the trouble? I should point out that I program clusters on my bench if that is a problem. I have a BCM wired in as well.
You are missing one file based on your PM and that is 15816943.bin which is not in that archive.
You have the utility file now and the last 2 files but you need that one to complete the DPS archive
Let me post the Program log when I atttempt to program with this Utility file, maybe somone will have some insights. Cheers.
Initializing Programming Session - v4.56.0000
Programming Initialization
Loading Calibration Files C:\DpsArch\maybenow.zip!
The VIT2 does not contain Part Number Information (VIT not populated)!
>> C:\Program Files (x86)\GM\J2534Wrapper\J2534Wrapper.dll v1.6.9.0
>> C:\ProgramData\VCX\Apps\PASSTHRU\VCXPT32.dll
>> ALLScanner;VXDIAG;04.04;;
>> Firmware Version: 1.9.4.2 VCX-NANO NEAGM34155, DLL Version: 04.04.210328, API Version: 04.04
>> Startup
>> Setup Base Mapping Matrix
>> Wakeup Links
01:14:29.672<[...L] 00 00 01 00 [0004] High Voltage
01:14:29.672>[...L] 00 00 01 00 [0004] TxMsgType
>> InitiateDiagnosticOperation (0x10) service with sub-func. 0x04 (wakeUpLinks)
01:14:30.203<[...L] 00 00 01 01 FD 02 10 04 00 00 00 00 [0012]
01:14:30.203>[...L] 00 00 01 01 FD 02 10 04 00 00 00 00 [0012] TxMsgType
01:14:30.250>[...L] 00 00 06 41 01 50 10 12 00 00 00 00 [0012]
>> Determine subnet configuration
01:14:31.781<[...L] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012]
01:14:31.781>[...L] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012] TxMsgType
>> Available subnets: LS-CAN
01:14:31.843<[...L] 00 00 01 01 FE 02 1A B0 00 00 00 00 [0012]
01:14:31.843>[...L] 00 00 01 01 FE 02 1A B0 00 00 00 00 [0012] TxMsgType
01:14:31.890>[...L] 00 00 06 4C 03 5A B0 60 34 38 32 33 [0012]
01:14:31.953<[...L] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012]
01:14:31.984>[...L] 00 00 06 41 03 5A B0 40 00 00 00 00 [0012]
01:14:31.984>[...L] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012] TxMsgType
>> Base Mapping Matrix:
>> ECU 0x60 on LS-CAN (ReqCANId: 0x0000024C, RspCANId: 0x0000064C)
>> ECU 0x40 on LS-CAN (ReqCANId: 0x00000241, RspCANId: 0x00000641)
>> InitiateDiagnosticOperation (0x10) service with sub-func. 0x02 (disableAllDTCs)
01:14:33.515<[...L] 00 00 01 01 FE 02 10 02 00 00 00 00 [0012]
01:14:33.515>[...L] 00 00 01 01 FE 02 10 02 00 00 00 00 [0012] TxMsgType
01:14:33.562>[...L] 00 00 06 41 03 7F 10 12 00 00 00 00 [0012]
01:14:33.609<[...L] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012]
01:14:33.640>[...L] 00 00 06 4C 01 50 B0 60 34 38 32 33 [0012]
01:14:33.640>[...L] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012] TxMsgType
01:14:35.172<[...L] 00 00 01 01 FE 01 28 00 00 00 00 00 [0012]
01:14:35.172>[...L] 00 00 01 01 FE 01 28 00 00 00 00 00 [0012] TxMsgType
01:14:35.203>[...L] 00 00 06 4C 01 68 B0 60 34 38 32 33 [0012]
01:14:35.250<[...L] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012]
01:14:35.297>[...L] 00 00 06 41 01 68 10 12 00 00 00 00 [0012]
01:14:35.297>[...L] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012] TxMsgType
>> ReportProgrammedState (0xA2) service
01:14:36.875<[...L] 00 00 01 01 FE 01 A2 00 00 00 00 00 [0012]
01:14:36.875>[...L] 00 00 01 01 FE 01 A2 00 00 00 00 00 [0012] TxMsgType
01:14:36.922>[...L] 00 00 06 4C 02 E2 00 60 34 38 32 33 [0012]
01:14:37.000<[...L] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012]
01:14:37.047>[...L] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012] TxMsgType
>> Number of detected programmable ECUs: 1
01:14:38.656<[...L] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012]
>> Enable Programming Mode
>> ProgrammingMode (0xA5) service with sub-func. 0x2 (requestProgrammingModeHighSpeed) on LS-CAN
01:14:38.750<[...L] 00 00 01 01 FE 02 A5 02 00 00 00 00 [0012]
01:14:38.750>[...L] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012] TxMsgType
01:14:38.750>[...L] 00 00 01 01 FE 02 A5 02 00 00 00 00 [0012] TxMsgType
01:14:38.781>[...L] 00 00 06 41 01 E5 10 12 00 00 00 00 [0012]
01:14:38.781>[...L] 00 00 06 4C 01 E5 00 60 34 38 32 33 [0012]
01:14:40.390<[...L] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012]
>> ProgrammingMode (0xA5) with sub-func. 0x03 enableProgrammingMode)
01:14:40.453<[...L] 00 00 01 01 FE 02 A5 03 00 00 00 00 [0012]
01:14:40.453>[...L] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012] TxMsgType
01:14:40.453>[...L] 00 00 01 01 FE 02 A5 03 00 00 00 00 [0012] TxMsgType
01:14:42.172<[...L] 00 00 01 01 FE 01 3E 00 00 00 00 00 [0012]
>> Enable MixedFormatFrames (ignore failure)!
Establishing Connections
Preparing Controller
Utility File: 20825549.BIN
Utility File Step=01 Opcode=01
Utility File Step=02 Opcode=27
01:14:42.703<[...L] 00 00 02 4C 27 01 [0006] FramePad
01:14:42.703>[...L] 00 00 01 01 FE [0005] ExtAddress TxDone TxMsgType
01:14:42.703>[...L] 00 00 02 4C [0004] TxDone TxMsgType
>> * Timeout Condition: ECU DID NOT RESPOND - Invoke RETRY LOGIC!
01:14:44.234<[...L] 00 00 02 4C 27 01 [0006] FramePad
01:14:44.234>[...L] 00 00 02 4C [0004] TxDone TxMsgType
01:14:45.500>[...L] 00 00 06 4C 7F 27 37 [0007]
01:14:47.531<[...L] 00 00 02 4C 27 01 [0006] FramePad
01:14:47.531>[...L] 00 00 02 4C [0004] TxDone TxMsgType
01:14:47.578>[...L] 00 00 06 4C 7F 27 37 [0007]
01:14:49.625<[...L] 00 00 02 4C 27 01 [0006] FramePad
01:14:49.625>[...L] 00 00 02 4C [0004] TxDone TxMsgType
01:14:49.672>[...L] 00 00 06 4C 7F 27 37 [0007]
01:14:51.718<[...L] 00 00 02 4C 27 01 [0006] FramePad
01:14:51.718>[...L] 00 00 02 4C [0004] TxDone TxMsgType
01:14:51.765>[...L] 00 00 06 4C 7F 27 37 [0007]
01:14:53.828<[...L] 00 00 02 4C 27 01 [0006] FramePad
01:14:53.828>[...L] 00 00 02 4C [0004] TxDone TxMsgType
01:14:53.875>[...L] 00 00 06 4C 7F 27 37 [0007]
01:14:55.922<[...L] 00 00 02 4C 27 01 [0006] FramePad
01:14:55.922>[...L] 00 00 02 4C [0004] TxDone TxMsgType
01:14:55.953>[...L] 00 00 06 4C 67 01 6D 99 [0008]
01:14:55.968<[...L] 00 00 02 4C 27 02 63 87 [0008] FramePad
01:14:55.968>[...L] 00 00 02 4C [0004] TxDone TxMsgType
01:14:56.015>[...L] 00 00 06 4C 67 02 [0006]
Utility File Step=03 Opcode=A2
01:14:56.031<[...L] 00 00 02 4C A2 [0005] FramePad
01:14:56.031>[...L] 00 00 02 4C [0004] TxDone TxMsgType
01:14:56.062>[...L] 00 00 06 4C E2 00 [0006]
Utility File Step=04 Opcode=50
Utility File Step=05 Opcode=1A
01:14:56.062<[...L] 00 00 02 4C 1A C1 [0006] FramePad
01:14:56.062>[...L] 00 00 02 4C [0004] TxDone TxMsgType
01:14:56.125>[...L] 00 00 06 4C 5A C1 01 8A 9E 31 [0010]
Utility File Step=06 Opcode=53
>> Data 1 = 00 00 00 00
>> Data 2 = 01 8a 9e 31
>> Compare: Not Equal, Goto G3
Utility File Step=07 Opcode=34
01:14:56.140<[...L] 00 00 02 4C 34 00 00 00 01 06 [0010] FramePad
01:14:56.140>[...L] 00 00 02 4C [0004] TxDone TxMsgType
01:14:56.187>[...L] 00 00 06 4C 7F 34 22 [0007]
Utility File Step=12 Opcode=EE
>> ReturnToNormalMode (0x20) service
01:14:56.609<[...L] 00 00 01 01 FE 01 20 00 00 00 00 00 [0012] FramePad
01:14:56.609>[...L] 00 00 01 01 FE 01 20 00 00 00 00 00 [0012] TxMsgType
01:14:56.625>[...L] 00 00 06 4C 01 60 34 22 8A 9E 31 00 [0012]
01:14:56.640>[...L] 00 00 06 41 01 60 00 00 00 00 00 00 [0012]
(06-22-2025, 04:52 PM)Dezzz Wrote: ZooperDooperSo I can see 2 possible issues in that section there, first is did you install and run techline connect with the vxdiag interface connected? Because they use the same serial number as the mdi clones that will get you banned from tlc.
>> Startup
>> Wakeup Links
Second is you said your programming ipcs? Those vxdiags dont work on any module that is class 2/swcan/low speed can and most older gm ipcs before say 2012 are class 2
Thanks given by: Dezzz
24
06-22-2025, 10:59 PM
(06-22-2025, 05:24 PM)Gmguy Wrote:(06-22-2025, 04:52 PM)Dezzz Wrote: ZooperDooperSo I can see 2 possible issues in that section there, first is did you install and run techline connect with the vxdiag interface connected? Because they use the same serial number as the mdi clones that will get you banned from tlc.
>> Startup
>> Wakeup Links
Hello thanks for you reply, I never made any attempt to run techline, I didnt even have a chance to enter a VIN in my subscriptions area. I would have thought the VXDIAG interface is an approve aftermarket device? I've read that using J2534 pass-through ONLY will be safe? I'm testing DPS with 07-09 clusters on the GMLAN protocol. DPS works normally, it works and pulls module info from the IPCS and just for fun I ran the MEC to zero archive which completed successfully.
Cheers
Cheers.
25
06-23-2025, 12:31 AM
Well did you find the missing file or are you trying to program with an incomplete archive?
If the archive is incomplete then you are wasting your time as it will never work!
26
06-23-2025, 06:26 AM
(06-23-2025, 12:31 AM)ZooperDooper Wrote: Well did you find the missing file or are you trying to program with an incomplete archive?
Hey Zooper, I have a known good MCU dump from a youtuber which was taken from a 2007 cluster using a jlink adapter through the Jtag connection on the actual circuit board. I tried building the missing 15816943 archive with the appropriate blocks from this dump file, created the archive with this missing block plus the calibration bins from the repository along with the utility file given from Tek earlier. Every attempt with or without a complete archive returns the error posted earlier. Im giving up for now with this project, thanks for your interest and help.
Cheers
27
06-23-2025, 06:43 AM
(06-23-2025, 06:26 AM)Dezzz Wrote:(06-23-2025, 12:31 AM)ZooperDooper Wrote: Well did you find the missing file or are you trying to program with an incomplete archive?
Cheers
I doubt you built the file correctly and no offence intended but it has to not only be the correct size it has to have the correct checksum for DPS to use.
