Audi A4 B8 1B-Active steering module replacement coding (SVM issue)
I have a headbanging problem with that car.
A4 B8 avant, water got into the active steering module and totally destroyed it. Found a replacement part with the latest part number 8K0907144E.
Audi doesn't provide an SVM code for this module in etka per the dealer staff, we tried cheating and providing the svm xchange code XCHG1BA001 but the server still wont accept the part for coding. Any option out of this beside getting a new module ?
Flash it what is it asking for now on test plan ??
Online Coding Vw, Skoda , Audi , Seat - Via Odis No Charge When Failed - I Can Immo Off /Clone All Dsg And all Also Edit Mileage for All Dsg/ Med17 - edc17 Immo off - Clone All edc17 med17 ,radio code , component protection . Install Latest Odis
post or send your vin
After the change code entry odis flashed the central electric, then the test plan got stuck at the active steering coding... It would attempt to code it then ask to cycle the key over and over.
vin is WAUVF68KX9A105971
(06-24-2023, 05:58 PM)julienjj Wrote: After the change code entry odis flashed the central electric, then the test plan got stuck at the active steering coding... It would attempt to code it then ask to cycle the key over and over.
This sounds like a cable issue. Replace your cable, enough data is not being transferred properly because of weak or damaged cable you use thus you get stuck in the process or just loop. Did you flash 44 with ODIS E? 8K0907144E is [font="MHH Font", Calibri, sans-serif]A5 part but can be flashed. Do flash before SVM.[/font]
[Image: tumblr_pbrioaGZQH1r5mggso1_500.gif]
according to the vin number, this should be the right partnumber. make sure the module isn't flashed before (check if it shows the same part number on diagnosis)
It was flashed for sure before, It is latest firmware is revision F that audi pushed around 2014. I think all used modules are gonna be that revision.
It does not work like that. Flash it to E and svm will pick it up.
Thanks given by: julienjj
(06-24-2023, 09:16 PM)Michel R32 Wrote: It does not work like that. Flash it to E and svm will pick it up.
Thanks for the advice, I will try monday to roll it back.
06-14-2026, 05:29 PM
06-14-2026, 02:35 PM
06-12-2026, 07:10 PM
