  • 3 Vote(s) - 3.67 Average
BimmerLink _ BimmerCode _ BimmerBTool Expert _ BimmerUtility _ BimmerInsight
BimmerLink 2.36.2
BimmerCode 4.29.0
BimmerCode 4.3 for iOS
BimmerBTool 3.7.8 Expert
BimmerBTool 3.8.11 Lite
BimmerUtility 1.14.07
BimmerInsight 2.2.3
BimmerCode: Coding hidden functions, changing comfort parameters and interface design.
BimmerLink: Reading and clearing DTCs, real-time sensor monitoring, and registering battery replacements.
BimmerBTool Expert: In-depth work with diesel engines, managing DPF regeneration and checking injectors.
BimmerBTool Lite: Check adapter compatibility with your vehicle before purchasing the full version.
BimmerUtility: Advanced NCD file editing and coding for the latest F, G, and I series models.
BimmerInsight: Detailed decoding of fault codes with expert repair recommendations.
[Image: bmw-Bimmer-Link-Bimmer-Code-Bimmer-BTool...nsight.jpg]
Need it? Push button Thanks, PM for pass | or by email right now.
.txt
BimmerLink Code BTool Utility Insight new.txt
598
34 bytes
BimmerUtility - is it mod apk?
Thanks given by: Profixit , rivercz
(03-06-2026, 02:58 AM)haker123 Wrote: BimmerUtility - is it mod apk?
Yes, must be full.
BimmerLink 2.36.2 - can't install via SAI, reports some error...
BimmerCode 4.29.0 - doesn't FULL - mod. (Latest full is 4.25.4)
I haven't tried the other apps
(03-07-2026, 02:39 AM)haker123 Wrote: BimmerLink 2.36.2 - can't install via SAI, reports some error...
"Latest full is 4.25.4" - why do you think so?
I would like to have a newer full BimmerCode, but which works (full mod)
Have you working one?
(03-07-2026, 06:11 PM)haker123 Wrote: I would like to have a newer full BimmerCode, but which works (full mod)
I will check when possible. They should work
Hello, I can't run BimmerInsight, after running it it tells me to download the new version from the Play Store.
(04-15-2026, 12:23 AM)kuba2507 Wrote: Hello, I can't run BimmerInsight, after running it it tells me to download the new version from the Play Store.
Hi, have you tried doing what the program asks you to do?
