BimmerLink _ BimmerCode _ BimmerBTool Expert _ BimmerUtility _ BimmerInsight - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Mobile Automotive Android/IOS/Windows CE (https://mhhauto.com/Forum-Mobile-Automotive-Android-IOS-Windows-CE) +--- Thread: BimmerLink _ BimmerCode _ BimmerBTool Expert _ BimmerUtility _ BimmerInsight (/Thread-BimmerLink-BimmerCode-BimmerBTool-Expert-BimmerUtility-BimmerInsight) |
BimmerLink _ BimmerCode _ BimmerBTool Expert _ BimmerUtility _ BimmerInsight - Aleksey-MS - 03-06-2026 BimmerLink _ BimmerCode _ BimmerBTool Expert _ BimmerUtility _ BimmerInsight BimmerLink 2.36.2 BimmerCode 4.29.0 BimmerCode 4.3 for iOS BimmerBTool 3.7.8 Expert BimmerBTool 3.8.11 Lite BimmerUtility 1.14.07 BimmerInsight 2.2.3 BimmerCode: Coding hidden functions, changing comfort parameters and interface design. BimmerLink: Reading and clearing DTCs, real-time sensor monitoring, and registering battery replacements. BimmerBTool Expert: In-depth work with diesel engines, managing DPF regeneration and checking injectors. BimmerBTool Lite: Check adapter compatibility with your vehicle before purchasing the full version. BimmerUtility: Advanced NCD file editing and coding for the latest F, G, and I series models. BimmerInsight: Detailed decoding of fault codes with expert repair recommendations. ![]() Need it? Push button Thanks, PM for pass | or by email right now. RE: BimmerLink _ BimmerCode _ BimmerBTool Expert _ BimmerUtility _ BimmerInsight - haker123 - 03-06-2026 BimmerUtility - is it mod apk? RE: BimmerLink _ BimmerCode _ BimmerBTool Expert _ BimmerUtility _ BimmerInsight - Aleksey-MS - 03-06-2026 (03-06-2026, 02:58 AM)haker123 Wrote: BimmerUtility - is it mod apk? Yes, must be full. RE: BimmerLink _ BimmerCode _ BimmerBTool Expert _ BimmerUtility _ BimmerInsight - haker123 - 03-07-2026 BimmerLink 2.36.2 - can't install via SAI, reports some error... BimmerCode 4.29.0 - doesn't FULL - mod. (Latest full is 4.25.4) I haven't tried the other apps RE: BimmerLink _ BimmerCode _ BimmerBTool Expert _ BimmerUtility _ BimmerInsight - Aleksey-MS - 03-07-2026 (03-07-2026, 02:39 AM)haker123 Wrote: BimmerLink 2.36.2 - can't install via SAI, reports some error... "Latest full is 4.25.4" - why do you think so? RE: BimmerLink _ BimmerCode _ BimmerBTool Expert _ BimmerUtility _ BimmerInsight - haker123 - 03-07-2026 I would like to have a newer full BimmerCode, but which works (full mod) Have you working one? RE: BimmerLink _ BimmerCode _ BimmerBTool Expert _ BimmerUtility _ BimmerInsight - Aleksey-MS - 03-10-2026 (03-07-2026, 06:11 PM)haker123 Wrote: I would like to have a newer full BimmerCode, but which works (full mod) I will check when possible. They should work RE: BimmerLink _ BimmerCode _ BimmerBTool Expert _ BimmerUtility _ BimmerInsight - kuba2507 - 04-15-2026 Hello, I can't run BimmerInsight, after running it it tells me to download the new version from the Play Store. RE: BimmerLink _ BimmerCode _ BimmerBTool Expert _ BimmerUtility _ BimmerInsight - Aleksey-MS - 04-15-2026 (04-15-2026, 12:23 AM)kuba2507 Wrote: Hello, I can't run BimmerInsight, after running it it tells me to download the new version from the Play Store. Hi, have you tried doing what the program asks you to do? |
