NAG 1
Location OfflineNewbie
0
Thanks Given: 3
Thanks Received: 4 (2 Posts)
I need help to fix CAL872 on DAS (Multiplexer is a Part D4).
I've used the search, but I can't find any fixes for my Version (It's the original DAS XENTRY 07/2014).
Com-Port settings are ok.
HHT works fine, but DAS doesn't. In the cal.ini I put "Part D"; I tried also with "Part D2", but it doesn't works.
It would be very nice if somewone can help me.
Thank you in advance.
Best regards,
Georg
130
Thanks Given: 1270
Thanks Received: 635 (279 Posts)
673
17
CAL872 fix is always available in Newguide2i! That error always has something to do with CALs so try a 2011 fixed bin folder! Do a fresh installation, apply blacklistfix then after that open fixed bin folder to see which files you will be replacing, cut your original files and save them b4 replacing them just so you can replace them if things go bad!
I have Xentry Das 05/2014 running well with both SD Connect and C3 PartD (not D4- original) so it's a matter of trying you know
“We, the unwilling, led by the unknowing, are doing the impossible for the ungrateful. We have done so much, for so long, with so little, we are now qualified to do anything with nothing.”
NAG 1
0
Thanks Given: 3
@pesona: which patch did you mean?
3,178
Thanks Given: 7612
1,696
53
i updated post #3 above.
hope this patch solve your problem.
NAG 1
0
Thanks Given: 3
Thank you very much pesona ! This patch works well, successfully tested on an W203.
...all problems are solved now!
3,178
Thanks Given: 7612
1,696
53
11-20-2016, 06:29 PM
(This post was last modified: 11-20-2016, 06:29 PM by pesona.)
No problem mate. you are welcome and i am glad you solve your problem.
