CAL 872 in DAS with Part D4 Multiplexer - Printable Version
+---- Thread: CAL 872 in DAS with Part D4 Multiplexer (/Thread-CAL-872-in-DAS-with-Part-D4-Multiplexer)
CAL 872 in DAS with Part D4 Multiplexer - NAG 1 - 11-18-2016
Hello,
I need help to fix CAL872 on DAS (Multiplexer is a Part D4).
I've used the search, but I can't find any fixes for my Version (It's the original DAS XENTRY 07/2014).
Com-Port settings are ok.
HHT works fine, but DAS doesn't. In the cal.ini I put "Part D"; I tried also with "Part D2", but it doesn't works.
It would be very nice if somewone can help me.
Thank you in advance.
Best regards,
Georg
RE: CAL 872 in DAS with Part D4 Multiplexer - Dollsburg - 11-18-2016
CAL872 fix is always available in Newguide2i! That error always has something to do with CALs so try a 2011 fixed bin folder! Do a fresh installation, apply blacklistfix then after that open fixed bin folder to see which files you will be replacing, cut your original files and save them b4 replacing them just so you can replace them if things go bad!
I have Xentry Das 05/2014 running well with both SD Connect and C3 PartD (not D4- original) so it's a matter of trying you know
RE: CAL 872 in DAS with Part D4 Multiplexer - pesona - 11-19-2016
@Dollsburg thanks for the answer.
no offense, imho, the 2011 blacklist fix will make another problem if you apply to 2014 version especially for MB BUS.
in fact, for 2015 upward, your approach will make problem for all type of vehicles especially if you do online.
latest DAS will check and compare the version of cal.sli, cal_real.dll to its DAS' version.
it is always better, if have to patch, use the same version.
@georg
try this patch for your 07-2014 version (version 7.4.0.0)
[attachment=155070]
hope this help
RE: CAL 872 in DAS with Part D4 Multiplexer - NAG 1 - 11-19-2016
@pesona: which patch did you mean?
i updated post #3 above.
hope this patch solve your problem.
RE: CAL 872 in DAS with Part D4 Multiplexer - NAG 1 - 11-20-2016
Thank you very much pesona ! This patch works well, successfully tested on an W203.
...all problems are solved now!
RE: CAL 872 in DAS with Part D4 Multiplexer - pesona - 11-20-2016
No problem mate. you are welcome and i am glad you solve your problem.
