Thanks Given: 179
Thanks Received: 112 (51 Posts)
189
28
211, 164, 251, etc...
What tricks are you using to calibrate weight sensors instead of using the special $900 MB weights. I just can't justify that expense. Only need it a few times a year.
Thinking of trying small weights but need to know if you guys know what exact weight and how to. Help please
dunnnia
Location OfflineJunior Member
Thanks Given: 313
Thanks Received: 19 (10 Posts)
83
14
HI,simply put the tank with water.The DAS show you how much kg you need.Done with success.
Thanks Given: 179
189
28
A 12 gallon container should work correct?
2,095
Thanks Given: 14574
6,536
46
We have used cases of oil, weights from a bar-bell... ect.. anything with the correct weight..
Thanks Given: 179
189
28
I've only ever used the proper weights when I was at dealer. Wasn't sure if car needed specific weight in each corner or just the proper total weight. Thanks guys
