Calibrating WSS for passenger seat? Any tricks? - Printable Version
+---- Thread: Calibrating WSS for passenger seat? Any tricks? (/Thread-Calibrating-WSS-for-passenger-seat-Any-tricks)
Calibrating WSS for passenger seat? Any tricks? - 93r1 - 12-17-2014
211, 164, 251, etc...
What tricks are you using to calibrate weight sensors instead of using the special $900 MB weights. I just can't justify that expense. Only need it a few times a year.
Thinking of trying small weights but need to know if you guys know what exact weight and how to. Help please
RE: Calibrating WSS for passenger seat? Any tricks? - dunnnia - 12-17-2014
HI,simply put the tank with water.The DAS show you how much kg you need.Done with success.
RE: Calibrating WSS for passenger seat? Any tricks? - 93r1 - 12-17-2014
A 12 gallon container should work correct?
RE: Calibrating WSS for passenger seat? Any tricks? - Rocinante - 12-17-2014
We have used cases of oil, weights from a bar-bell... ect.. anything with the correct weight.. Smile
RE: Calibrating WSS for passenger seat? Any tricks? - 93r1 - 12-18-2014
I've only ever used the proper weights when I was at dealer. Wasn't sure if car needed specific weight in each corner or just the proper total weight. Thanks guys
RE: Calibrating WSS for passenger seat? Any tricks? - habs44 - 01-24-2017
Is DAS the only tool that can do this?
Does anyone know an aftermarket tool that can calibrate WSS?
ThanksSmile
