Hello guys . I've got this captiva with problem in abs. C0550 and changed it with another used abs . I had two abs units and tried to program to match the original one . But ended with 2 dtc
U0102 can-bus com. With TCCM (transfer case control module)
U2105 CAN-BUS no comm with ECM
the two modules i tried ended with these 2 dtc's . This captiva is FWD and the two abs i had seems from 4×4 captiva .
I did changed the VIN. But didnt solve completely
I tried with sps online programming to change the calibration to match the car . But it keep failing due to no match
Any idea how to virgnize. Or write the old calibration sw. Into the new abs??
Vin :3GNAL7EK6DS599071
Thank you all
Thank you all
