Chevrolet Camaro 2018- Unable to program SRS module using SPS online-anyone?
Hi.
I got Chevrolet Camaro 2018 and i need to replace SRS module, installed used module, trying to do sps and it gives me this error on attachment, anyone got same issue?
Issue is same on 2 srs modules, first stage it flashes fine and next one it always freezes while trying to program on about 10%
Using MDI interface, on 2 laptops got same issue.
If anyone can help ill really appreciate, i have whatsapp.
Is new or used module ?
Pm me vin and srs part number
used module
IT IS FAILING THE IMMO LEARN BECAUSE IT'S A USED MODULE. SPS WON'T BE ABLE TO FIX IT.
change vin with dps . get files from spscache and prepare it for dps . if it gives error , module already programmed. or try with carprog . both of 2 way gives error . buy new module. is it 5seed or 2seed ?
(11-15-2024, 04:21 PM)mehmetcengiz Wrote: change vin with dps . get files from spscache and prepare it for dps . if it gives error  , module already programmed.  or try with carprog . both of 2 way gives error . buy new module. is it  5seed or 2seed ?
how to prepare file for DPS??
get the files from sps cache and post them i will make you a dps file or just pm me the files
PM SEND
- ALLDATA EU/USA - HAYNES PRO - MİTHCELL PRO DEMAND - FDRS İDS LİCENSE - FORD ACCOUNT - GM SPS - FİAT EPER -
(04-28-2025, 01:48 PM)CarDiagnostc Wrote: PM SEND
SCAMMER.  https://mhhauto.com/Thread-JLR-Topix-Pat...r-1-DAY-30
06-11-2026, 10:56 PM
06-11-2026, 01:07 PM
06-10-2026, 10:34 AM
