Hello.
The problem is not solved, the problem has become even bigger. One of the forum members made me a scr_off file. After recording, the remaining mileage decreased from 500 to 200 kilometers. Also, errors appeared on the disabled scr module. The manufacturer of the scr_off solution recommended that I disable the module. Any thoughts on how to fix this?
(09-06-2024, 12:22 PM)Alex_Do Wrote: Hello.
Three masters sent three, 100 percent identical files. There is an idea that the file is created automatically. When disabling the adblue unit, 7 errors appear, indicating that the scr is disabled. Also, the scr icon blinks on the dashboard and a warning appears that the car will stop working after 200 km.
There must be some kind of instructions together with patched file. Something like to disconnect some sensors...
Also if you want to have good quality it can't be free IMHO.
I had this with Zafira C Tourer, had to do the Adblue resets then write the file in on the bench, doing the delete via obd port created a fault at the end of the write, doing on the bench via pinout sorted it.
809-08-2024, 04:47 PM (This post was last modified: 09-08-2024, 04:57 PM by Alex_Do.)
(09-08-2024, 12:04 AM)andyl Wrote: I had this with Zafira C Tourer, had to do the Adblue resets then write the file in on the bench, doing the delete via obd port created a fault at the end of the write, doing on the bench via pinout sorted it.
There are no such problems with Opel. A prepared file impairs engine performance. Tried 4 different files
(09-07-2024, 11:13 PM)KIR73 Wrote: There must be some kind of instructions together with patched file. Something like to disconnect some sensors...
You are right, there is a description. The problem is that the automatic solution for the E98 (Opel) unit is not suitable for Captiva. EGR errors appear, and if you disable the SCR module, 6 more SCR errors appear. In my case, the purchased option is 100 percent the same as the free one)))
