Chevrolet Cruze automatic gearbox problem
Hi guys,I have a Chevrolet cruze year 2013 , 2.0 cdi 163 HPdiesel , so this morning my car got "stuck in the sand". It starts normally , no check engine light , I put it on D ,it works for about 5 sec and after that the automatic gearbox stops working. Reverse is not working at all. If I let the car sit for about 10 min after I will start it again it will work in D for about 5 sec again and after that again dead.
I have the following errors :
U0402-01 - invalid data received from transmission control module - Short to Battery
U0402-04 - invalid data received from transmission control module- Open
P0700-00 - transmission control module requested MIL
P1761-00 - up and down shift switch signal message counter incorrect
U0100-00 - lost communication with engine control module
U0121-00 - lost communication with electronic brake control module
U0140-00 - lost communication with body control module
Any help where to start will be much appreciated.
Thank you guys!
Rep+Thx if i helped. Kolo
“A man’s true wealth is the good he does in this world.”
06-11-2026, 10:56 PM
06-11-2026, 01:07 PM
06-10-2026, 10:34 AM
