136
Thanks Given: 686
Thanks Received: 253 (102 Posts)
591
180
Hello everyone, who can help with changing the pin?
Thanks advance
if I helped you don't forget to say thanks and leave a reputation
18
Thanks Given: 274
Thanks Received: 90 (76 Posts)
535
29
Can be done remotely, pm me
136
Thanks Given: 686
591
180
Hello everyone
These guys wdariusw , Manhbuiduc , helped me with this problem, I think they are honest and do a good job
But the problem has not been solved yet
As soon as I figure it out, I will let you know
Pedriux
Location OfflineJunior Member
136
Thanks Given: 244
Thanks Received: 355 (24 Posts)
62
I can solve that job, send a private message
136
Thanks Given: 686
591
180
(05-09-2025, 07:41 AM)RoninDusette Wrote: Program the PCM first. Make sure it has the VIN set properly. Then, do an ABS Static Initialization. It will pull the VIN from the PCM.
what program can I use to make Static Initialization?
136
Thanks Given: 686
591
180
thanks comrades I figured this out, TROY helped
Now the task is how to unlock EPS with malfunction C0460(A) today this is a problem
