839
Thanks Given: 677
Thanks Received: 1965 (379 Posts)
1,333
286
Hello guys! I have got a problem with chevrolet captiva abs. The car comes to our workshop with esp and abs lights on and dtc c0551-47 saying VIN its not coded. And this is correct because the vin coded have got 16 characters. I tried to code it with Launch like Antara and he coding ok but same dtc and only 16 characters on ecu info. Anyone coded this abs or know the way to do it? Thanks in advance!
If I helped you press REP
and THANKS
. It's free!
839
Thanks Given: 677
1,333
286
I found the problem I think. The bcm of the car havent got the correct vin of the car. I think they replaced it in other workshop and this is the problem. Anyone know how we can change vin on bcm? I have got autel and launch, or maybe manually reading the eeprom? Anyone did this job? Thanks.
and THANKS
. It's free!
Thanks Given: 28
Thanks Received: 38 (26 Posts)
101
What car is it exactly? (Model, Manufacture year etc)
Do you have an J2534 passthrough device ?
0
Thanks Given: 4
Thanks Received: 0 (0 Posts)
there is no vin rewrite function in autel for GM. you will either need to use tis2k, passthru with acdelco or eprom.
2,375
Thanks Given: 400
Thanks Received: 5812 (3906 Posts)
5,427
13
It may be possible in that year to just read the 93c66 from the BCM and edit the VIN.
If you do not click thanks and rate for my free help, you will be put on ignore. No help next time.
Do NOT PM me for help, post it in the forum!
