(11-27-2014, 12:00 AM)mercedessd Wrote:(11-26-2014, 11:49 PM)LuisAndre Wrote:(11-26-2014, 11:02 PM)mercedessd Wrote: looks like it may be related to the HWID changing if the program to provice the code is closed and reopened.
new HWID is
BBE31802-FBF71C02-47123C00-00005666
No, it's not. The last 8 digits are used for random checksum. They will change everytime. The window is displayed because you have run the emulator on the megatool software. Follow the instructions on my previous post.
i did follow your advice, however none of those items were running.
i applied the patch, the program opens, i select DAS/XENTRY APP ID EMULATOR, for type i select compact4 -250, press install, shows a modify path window which reads Usage: modpath.exe {/add /del} <path>
click ok says all done good work, i close the widow, open starutilities then startkey center and then is when the error show, also shows if i try to install das from dvd
No mate. On post #1 you have 2 links. One for megatool application and another one, my emulator. You must run my emulator, as the last procedure, and not the loader that runs megatool app. That's your mistake.
![[Image: ywEs1be.png]](http://i.imgur.com/ywEs1be.png)
Thanks given by: avandgarde , takis , vincano , Smallville , Yudi , webmaster , daxxer
