[email protected]
DAS Xentry Multi Solution 2014
192
12-05-2014, 02:23 AM
Hello, the first key worked fine!
Many thanks to Mr. Luis!
Please can i have a second activation for my second Laptop?
here is my HWID: BFA91862-FFBF1C62-40143C00-00003273
Many thanks
Many thanks
193
12-05-2014, 05:48 AM
(This post was last modified: 12-05-2014, 05:48 AM by Smallville.)
(12-05-2014, 12:27 AM)ovidiu1967 Wrote: Hi webmaster
please help me again with activation code:
AFE9FA7F-FFFFFE7F-5015FCEA-000010FE
THANKS IN ADVANCE!
8FC9B3CE232027A6
(12-05-2014, 01:54 AM)mercedessd Wrote: please for HWID:
A8511800-E8451C00-43243C00-00001359
THANK YOU
9FCBB3CE349AC5D9
(12-05-2014, 02:23 AM)ChengLynn Wrote: Hello, the first key worked fine!
Many thanks
9FC9B3CE2360C5BB
> Remote Install Support <
> BMW ISPI ISTA Next - Offline iLeanLicense <
> DTS Monaco 9.04.016 - Full License - Database <
> %100 Proffessional Support <
194
12-05-2014, 11:26 AM
(This post was last modified: 12-05-2014, 11:27 AM by mercedessd.)
trying to update a clone of an original C4 in recovery mode running in a dell, when I started setup i had the 250 but after first dvd went back to 252 and HWID changed to:
BBE31802-FBF71C02-40123C00-000029BC
Also mega tool was giving error "APPID : Error : Z0E"
this was shown on lowest window below ready, but above where says
FUCK ALL CHEATERS
FUCK ALL CHEATERS
Thanks given by: ovidiu1967
195
12-05-2014, 09:59 PM
(12-05-2014, 11:26 AM)mercedessd Wrote: trying to update a clone of an original C4 in recovery mode running in a dell, when I started setup i had the 250 but after first dvd went back to 252 and HWID changed to:
FUCK ALL CHEATERS
Dont use MegaTool Solution
9FCBB3CE2728C5DB
Thanks given by: avandgarde , takis , Yudi
196
12-05-2014, 10:39 PM
(12-05-2014, 09:59 PM)Smallville Wrote:(12-05-2014, 11:26 AM)mercedessd Wrote: trying to update a clone of an original C4 in recovery mode running in a dell, when I started setup i had the 250 but after first dvd went back to 252 and HWID changed to:
FUCK ALL CHEATERS
9FCBB3CE2728C5DB
what should be used?
197
12-05-2014, 10:49 PM
(12-05-2014, 10:39 PM)mercedessd Wrote:(12-05-2014, 09:59 PM)Smallville Wrote:(12-05-2014, 11:26 AM)mercedessd Wrote: trying to update a clone of an original C4 in recovery mode running in a dell, when I started setup i had the 250 but after first dvd went back to 252 and HWID changed to:
FUCK ALL CHEATERS
9FCBB3CE2728C5DB
if you used Megatool Solution than you will run DAS_HWID_Patch
and dont use VboxService file
