14
Thanks Given: 643
Thanks Received: 184 (167 Posts)
1,303
263
[quote='swift' pid='1029538' dateline='1502824270']
[quote='fantomel' pid='1014780' dateline='1501175675']
DPF EGR Lambda Remover 2017.05 Keygen + Install Kits
Hallo FANTOMEL
Thanks very much for the software but works not for me WHY
install no problem keymaker works but wen the key is ready
it tell unable to save the file !!! i did it in other map no problem
but in DK --dpf or egr it wil not paste i have here WINDOWS VISTION
is this an problem ??
Rg Tks12
135
Thanks Given: 233
Thanks Received: 608 (27 Posts)
206
70
I do everything according to the instructions but write wrong licence
404
Thanks Given: 351
Thanks Received: 832 (40 Posts)
282
78
hello
its first time i use this program and i install it good but when try to start it, appears "Protections"
what can i do ?
i copy HW and generate it and make code.key and copy it in 3 folder but i get massege wrong license.
please help me
27
Thanks Given: 79
Thanks Received: 33 (13 Posts)
42
0
Hi friend,
The same situation is happening here.
Windows 7 ultimate 32bits use
Please help us
thanks
Thanks Given: 48
Thanks Received: 14 (8 Posts)
45
16
34
09-07-2017, 02:33 AM
(This post was last modified: 09-07-2017, 02:57 AM by arribasmotor.)
hi i try to install but, i have a window with protection.
i try to put the number appear down te PROTECTION
and also i try to remove the code.dll,when i remove that i get the ID
but the keygen not acept
can anyone help me?
thanks
709
Thanks Given: 2326
Thanks Received: 2447 (816 Posts)
2,014
125
First everyone who has the wrong license problem should read post #33 !
Second,try all to install and open it as administrator,go to properties on the .exe files sometimes windows block files from internet,so make sure that you ticked unblock.
The code.key should be inside the folder like:
c-program files-dkeam-dpf-code.key and code.dll together i think.
If i Helped,please press thanks and +rep buttons
0
Thanks Given: 30
Thanks Received: 11 (5 Posts)
22
excuse the trouble i wanted to ask if it was possible to have the key to upload the DPF file EGR Lambda Remover 2017.05 Keygen + Kits
