12,701
Thanks Given: 942
Thanks Received: 33028 (1243 Posts)
1,318
70
In ID window push CTRL+C, you will not see a message, make a new txt document, open it, inside Paste or CTRL+V, you will see ID there. Take only ID and put in KG and make key. Generated file put it in all 3 places and then open program.
If you like my post and it helped you please press
Thanks given by: dinho , diagnostix , Marcos , toine , svmipmf , Faiq , baubau , seva , SorinRo , Marco13 , ecupirates , Tspark , idriss36 , POLUTO
Thanks Given: 312
Thanks Received: 9 (8 Posts)
165
30
20
08-02-2017, 05:25 PM
(This post was last modified: 08-02-2017, 05:26 PM by codewarior273.)
Hi
First of all thanks to Fantomel for that valued offer of this software
I have a question when i try 1st to remove a dpf from a file and then the same file need to remove egr the software does not recognise the file. Same with the opposite order. But if i try to make only DPF or only EGR works fine. But both in the same file is impossible. Any solution on that?
Harza
Location OfflineJunior Member
0
Thanks Given: 183
Thanks Received: 5 (2 Posts)
34
Hi. I use Win xp professional 32 bit. It say "wrong license".
Any idea?
Thanks Given: 72
Thanks Received: 13 (9 Posts)
73
fantomel, you're the MAN!
Thanks Given: 39
Thanks Received: 32 (17 Posts)
131
25
24
08-06-2017, 05:42 PM
(This post was last modified: 08-06-2017, 11:56 PM by Danthe.)
It seems that it doesn't remove related DTCs, right?
14
Thanks Given: 643
Thanks Received: 184 (167 Posts)
1,303
263
[quote='Danthe' pid='1022394' dateline='1502023348']
HI Fantomel
i install but tool tell me not works Will it works on Windows Vista ??
Rg tks12
