Disable Malfunction warning from dash
Hello. Is it possible to disable/decode Malfunction warning from instrument cluster?
MB GLC 2016
DTC:
SG-EM-1 (Power Electronics Control Unit / Starter Alternator)
P0A9300 - The cooling system for the low temperature circuit has a malfunction.
What exactly do you want to disable? The warning lamp in dash or the report in the display? You can only disable a report (written warning message in dash) if you disable the function. In this particular case it will not be possible.
If it is a warning lamp it might be possible to disable it but it depends on the installed firmware and what car configuration you have.
How have you read out the error?
(Yesterday, 09:55 PM)fotom Wrote: What exactly do you want to disable? The warning lamp in dash or the report in the display? You can only disable a report (written warning message in dash) if you disable the function. In this particular case it will not be possible.
I want to disable malfunction warning which is displayed on IC.
Error is written in first post.
Users browsing this thread: trigital, 3 Guest(s)
