Disable Malfunction warning from dash - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Disable Malfunction warning from dash (/Thread-Disable-Malfunction-warning-from-dash) |
Disable Malfunction warning from dash - MrQuestion - 11-21-2026 Hello. Is it possible to disable/decode Malfunction warning from instrument cluster? MB GLC 2016 DTC: SG-EM-1 (Power Electronics Control Unit / Starter Alternator) P0A9300 - The cooling system for the low temperature circuit has a malfunction. RE: Disable Malfunction warning from dash - fotom - 11-21-2026 What exactly do you want to disable? The warning lamp in dash or the report in the display? You can only disable a report (written warning message in dash) if you disable the function. In this particular case it will not be possible. If it is a warning lamp it might be possible to disable it but it depends on the installed firmware and what car configuration you have. How have you read out the error? RE: Disable Malfunction warning from dash - MrQuestion - 11-22-2026 (Yesterday, 09:55 PM)fotom Wrote: What exactly do you want to disable? The warning lamp in dash or the report in the display? You can only disable a report (written warning message in dash) if you disable the function. In this particular case it will not be possible. I want to disable malfunction warning which is displayed on IC. Error is written in first post. |
