  • 17 Vote(s) - 3.29 Average
Eeprom erraser for 35160wt in new bmw 2016
HI~all
Does anybody know what tool can erase the new eeprom(35160WT) in the 2016 BMW dashboard.
thanks in advance.
Regards.
Press [Image: postbit_thx.gif] and [Image: postbit_reputation.gif].If this post helped you.
Look here maybe this work
[attachment=166107]
I have this programmer, but i wait for 35160 eeprom`s for trying.
I will not try on original
Thanks given by: AutoHaus786
i sucessfully erase 35160 with Martech , but i cant remenúmber if was marked wt.
Thanks given by: KriyenKPp
with codiprog you can erase M35160 without problem, work perfect
(01-29-2017, 03:30 AM)franke232 Wrote: with codiprog you can erase M35160 without problem, work perfect
Codiprog can not do this 35160 WT it hat an vinnr insite so you can not change it for another Fing20
[/quote]
ok, actually I haven't yet had a dash of 2016, I haven't seen the memory M35160 if it carries the same memory as those of 2015 -> 160D0WQ i'm are deleted without problems, I'm tired of doing it, I haven't yet had One from 2016 ....But if it's a 160D0WQ erases it, I can show it with a video if anyone want to see it
160D0WQ and 35160WT are not the same.
You will get 100% solution
no eraser for WT atm
Only safe way for these cars after 6/2016 is using MT350160WT emulator. otherwise you get red dot in dash
Thanks given by: bawarek , selim
05-24-2026, 07:55 PM
04-02-2026, 09:13 PM
