  • 17 Vote(s) - 3.59 Average
HOW TO: Throttle body reset electronically, without using the MB STAR diagnostic comp
If youre adding mods to your car, Id recommend you do this and also the ECU reset to clear any adaptations and 'freshen up' everything.
1 Pop the hood
2 put key in ign
3 turn the key to the first click on (not turning on the motor)
4 remove the cable going to the TB
5 turn the key one more click to the position right before the engine fires.
Now, you will wait 20 seconds. There will be a ERROR displayed on the dash. This means youre doing it right
6 after 20 seconds, click the key back down to the first position, position 1. (never remove the key)
7 plug back in the cable for the throttle body
8 start the motor and feel the calibrated throttle body deliver a little smoother ride.
From what Ive noticed, the idle is a bit lower and the response crisper.
Again for maximum effictiveness, also reset your ECU. That clears the learned shifting habits, and various other parameters.
Enjoy
IF IT HELP PLEASE PRESS THANKS + REPUTATION Fing32
