HOW TO: Throttle body reset electronically, without using the MB STAR diagnostic comp - Printable Version
+---- Thread: HOW TO: Throttle body reset electronically, without using the MB STAR diagnostic comp (/Thread-HOW-TO-Throttle-body-reset-electronically-without-using-the-MB-STAR-diagnostic-comp)
HOW TO: Throttle body reset electronically, without using the MB STAR diagnostic comp - sgtafric - 11-08-2016
If youre adding mods to your car, Id recommend you do this and also the ECU reset to clear any adaptations and 'freshen up' everything.
1 Pop the hood
2 put key in ign
3 turn the key to the first click on (not turning on the motor)
4 remove the cable going to the TB
5 turn the key one more click to the position right before the engine fires.
Now, you will wait 20 seconds. There will be a ERROR displayed on the dash. This means youre doing it right
6 after 20 seconds, click the key back down to the first position, position 1. (never remove the key)
7 plug back in the cable for the throttle body
8 start the motor and feel the calibrated throttle body deliver a little smoother ride.
From what Ive noticed, the idle is a bit lower and the response crisper.
Again for maximum effictiveness, also reset your ECU. That clears the learned shifting habits, and various other parameters.
Enjoy
